Smaller pully
Old Jul 25, 2014 | 06:22 AM
gasman's Avatar
Default Smaller pully
How are people able to put a size 3 pulley or smaller on your car?? I understand tune tune tune and scan for knock but dam I got all the goodies plus SS inter cooler, Xp cam, bored throttle body, and getting full headers next week... But zz performance said after I dyno tune after headers are on I shouldn't drop past my 3.25 pully...
Old Jul 25, 2014 | 07:23 AM
Every engine responds differently. Also you might need a larger intercooler if you are just running a short-stack.
Old Jul 25, 2014 | 09:22 AM
nitehawkjcb's Avatar
Gen V or Gen III? I'm on a 3.1 with hardly no knock on a Gen III with stock cam... so with any cam I could drop under a 3.0.
Old Jul 25, 2014 | 10:40 AM
gasman's Avatar
Gen 3
Old Jul 25, 2014 | 10:44 AM
Full size IC? How much timing at WOT?
Edit - nvm I saw you have a short stack. Bigger IC is the way to go. I dropped from a 3.4 to a 3.1 and took the timing back to stock with adding a full size IC. Keep in mind, it took me getting my heads ported to run a 3.4 pulley (Had like 10* of KR before, the heads knocked it down to blips of KR)
Old Jul 25, 2014 | 11:50 AM
gasman's Avatar
Yea I see what you saying but when I hear people say they got a 3.1 pr smaller pully I'm like what they doing I'm not
Old Jul 25, 2014 | 12:09 PM
turbo monte's Avatar
Ss ic is holding you back. Tune is magic as well. Also are you top swapped or originally supercharged? Na bottom ends have higher compression which will make more power without dropping as much pulley size.
With same exact mods on a car:
Higher compression=bigger pulley
Lower compression=smaller pulley
Still make near the same power just one makes more with engine other makes more with the blower.
Old Jul 25, 2014 | 12:51 PM
gasman's Avatar
No I'm supercharged.. Dale jr edition and yea zz performance said they could tune it to make it more powerfully after headers... And before anyone asks yes it's tuned up turbo tim does every one of my tunes from the dyno
Old Jul 25, 2014 | 12:52 PM
gasman's Avatar
And ok the SS intercooler might be holding me back I can accept that thought
Old Jul 25, 2014 | 01:13 PM
I also have mixed feelings on zzperformane tunes. I've heard some are ok and I've heard some were very poorly tuned.
