Service or No Service?
Old Sep 24, 2009 | 08:25 PM
GSchroeder's Avatar
Default Service or No Service?
So I got my '04 LS a few years back with 52K miles on it, and the tranny fluid completely black... and Ive heard from a few different people not to change it if it's black because the gears have already ground down, and the shavings actually help keep the transmission in line. Now I just hit 100K miles and did everything except the transmission...
Should I do a full service or just keep the fluid in check? This is my every day driver.
Old Sep 24, 2009 | 08:35 PM
hmm, i don't like any part of this issue, is it really black??? hopefully someone here can give some good advice to you on your tranny?
Old Sep 24, 2009 | 08:41 PM
Budsjlm's Avatar
i have heard that befor too... how bad is your fluid?
Old Sep 24, 2009 | 08:57 PM
GSchroeder's Avatar
BLACK... it was already seriously dark when I got it 2 years ago, and so far Ive just been keeping it up.... it's got dex 3, if that makes any difference. And remember its an LS, an LS that I occasionally drive like an SS
Old Sep 24, 2009 | 10:53 PM
MAMONTE's Avatar
BLACK!!! I've honestly NEVER seen black tranny fluid. I've heard the no changing thing before too..but IDK!
My opinion DO NOT take it in for a "flush" By a good brand Dexron 3 (normally i'd say get Dexron 6, but in this case stick with 3). And do a pan drop and filter change. This will change out 7.5 quarts of the 13 total quarts of fluid. I think this should be safe because your still leaving some old fluid in (almost half)...Then 50K later, do another pan drop/ filter change...
Nothing good can come from BLACK tranny fluid. That sounds bad already!
Old Sep 25, 2009 | 01:40 AM
moonlitmagik's Avatar
Time for a new tranny. Mine got to the point where it would heat up and not shift gears, then it just wouldn't go into drive period. Wasnt the shift linkage, wasnt the torque converter, it was the whole damn thing. I wound up getting it rebuilt because a new one would cost SO much money!
Old Sep 25, 2009 | 07:52 AM
Budsjlm's Avatar
if it was black when u got it u shouldn't be driving it like an ss more than likly the clutches inside your trany are toast i wouldn't do any kind of flush or serviceand start looking for a trany
Old Sep 25, 2009 | 07:56 AM
Budsjlm's Avatar
i'm actually verry suprised it's not slipping only black fluid in a trany i have seen was in a friends trany that lost every gear but first and reverse and it did it over time ...2nd went out first
Old Sep 25, 2009 | 07:57 AM
Budsjlm's Avatar
then od and then 3rd.... my opinion start looking for a trany befor u lose it
fever42
Jul 22, 2006 02:50 AM
akumageorges
Apr 12, 2006 03:30 PM
Stag
Feb 26, 2006 02:03 PM
06MonteSS
Dec 1, 2005 05:01 PM
warpath
May 22, 2005 03:40 PM
