Replacing coolant Elbow question
Old Sep 10, 2013 | 08:48 PM
ohara's Avatar
Default Replacing coolant Elbow question
Hey everyone, I am going to be changing the upper coolant elbow on my car Friday night and from what I have seen on the youtube video's it is fairly straight forward
Remove serpentine, remove upper cross bar, remove rad reservoir, remove top bolt on alternator as well as side and lower back bolts and lift up then remove elbow and ensure all parts are out of the holes, and then lube up the o rings with some penetrating oil and reinsert and then reverse process back to having everything put in.
Now is there anything I am missing? or does anyone have any tips that are nice to know before hand?
as always any and all help or information is truly appreciated
Old Sep 10, 2013 | 09:37 PM
There are two coolant Elbow's..
They aren't hard to change ..
Old Sep 11, 2013 | 11:34 AM
The o-rings do have a dry lube on them. I would not use a penetrating oil (as it can damage the o-ring material).
I have used the thinnest application of vaseline or plumbers lube (both have been used for o-rings in faucets) on the edge of the elbow going into something (but not the back, so don't lube the entire ring). The reason is:
- Thin application, going crazy with it and it's asking to have it slide out.
- On the surface going into a port so it is lubed going in, but should not have much if any lube to back out.
Old Sep 11, 2013 | 02:45 PM
owens91's Avatar
and another thing to add, i think we should encourage all of our members to go with is.... DORMAN ALUMINUM COOLANT ELBOWS, once you put these babies on you will never need to replace them again...and they do look slightly cooler
Old Sep 11, 2013 | 09:53 PM
ohara's Avatar
Thanks for the advice guys, it is appreciated, I saw on the video the guy recommended lubing the o rings, but didn't mention to go sparingly, so I will prob use the vaseline and keep her to a minimum.
I am not doing the aluminum elbows as I just don't have the time to wait for them to be shipped as no one local has them here. So it's going to be a job that will be done again, but I'm thinking it will give me a reason to rip things apart again and add some goodies while I'm doing it
Old Sep 12, 2013 | 08:28 AM
RonBoySS's Avatar
Good luck, it really isn't that hard to do & it was $350 to have done at a local shop. Was lucky had the Aluminum elbows local so hoping it is a one time repair.
Old Sep 13, 2013 | 09:06 PM
ohara's Avatar
well I got them changed tonight, without much difficulty at all, but did need an extra set of hand for putting the serpentine back on. Both of the elbows were cracked off at almost the same spot, the part that get larger with the o rings around them, the upper one was so clean of a break I honestly thought it didn't come with an o ring.
Thanks for the advice and tips, as always it is greatly appreciated.
Budsjlm
FWD Tech Guides '95-'07
Oct 29, 2015 05:01 PM
owens91
Mar 13, 2014 10:50 PM
turbo monte
Feb 23, 2014 11:15 PM
Dylan313
Apr 23, 2013 07:58 PM
blueSS
Jun 5, 2012 05:30 PM
