Removing Governor?
Old Jan 10, 2017 | 10:03 PM
AEhrman's Avatar
The seed limiter can be removed as posted above but keep in mind you don't want to make full throttle pulls in 4th gear because the trans can't handle it. 3rd gear will go over 110mph but just be sure when it goes to shift into 4th you back out to save your trans.
Is there a way to adjust the limiter as to reduce he risk of damaging the transmission? I'm a bit curious as I have a 2002 Monte Carlo LS
Old Jan 11, 2017 | 04:22 PM
turbo monte's Avatar
You can tune the car to not shift into 4th if above a certain throttle percent, that's how I have mine setup
Old Jan 11, 2017 | 07:59 PM
AEhrman's Avatar
Thank you
Old Jan 12, 2017 | 12:15 AM
Interesting, will remember to mention that to Matt...
Red Monte Carlo
Jul 23, 2015 05:10 PM
irulesoha
Feb 8, 2010 10:07 PM
04superjr
Jan 9, 2009 09:56 PM
ltrain925
Jan 8, 2008 04:49 PM
TheElabaman
Sep 24, 2006 11:12 AM
