Redline D4 or D6?
Old Oct 11, 2012 | 09:50 AM
davesbedroom's Avatar
Default Redline D4 or D6?
My 2004 SS Supercharged just hit 100,000 miles!!!
I dropped the pan and changed the filter ~30,000 miles ago. I used the AC Delco filter, and Redline D4 ATF. ~22,000 miles before that I changed the filter and used Amsoil ATF. Now, I am thinking of using Redline D6 ATF. The fluid is dirty and smells burnt and when you check it there are bubbles.
Any opinions on a better ATF for this transmission?
Old Oct 15, 2012 | 01:43 PM
Wow... no opinions on ATF!? Do you guys just wait to have to pay big $$ on a rebuild?
Old Oct 15, 2012 | 01:50 PM
Why not just go with the manufacturer recommended and not beat on it. There's a recommended fluid for a reason. As long as you maintain it (change fluid, filter etc) you shouldn't have an issue.
Dexron VI is what's recommended, if you searched the topic this is what you would come up with:
atf - Monte Carlo Forum - Monte Carlo Enthusiast Forums - Threads Tagged with atf
Old Oct 18, 2012 | 07:55 AM
Oh ok.. thanks. I got the owners manual out of the glove box and on page 6-12 Recommended Fluids and Lubricants for the Automatic Transaxle it says DEXRON®-III Automatic Transmission Fluid.
Good to go... that stuff is cheap too. Thanks!!!!!!
Old Oct 18, 2012 | 08:17 AM
MAMONTE's Avatar
I would not use any of the Dexron III on the market. None of them are licensed or approved by GM anymore. GM updated to formula for Dexron, changing it dramatically. GM only licenses Dexron VI now, which is backwards compatible with Dexron III.
Valvoline makes a fully synthetic version of Dexron VI, i've used it my cars entire life and i'm at 165K. I change my tranny fluid every 25-35K.
Old Oct 18, 2012 | 06:28 PM
monte07's Avatar
keep with dex VI you might have a gasket leak on the pan. i do my trans fluid about 35 to 38k. do to wanting to keep the trans do to it is the weakest link in our powertrain. not just that i used redline in a trans in my honda only had the car for two dars till i rolled it and blew the powertrain. i seen redline not help at all the trans to keep it cool and lubed in the case
Old Oct 18, 2012 | 11:01 PM
x2 for OEM. The fluid shouldn't be that burnt and dirty after 30k either.
Special trans fluid isn't going to prevent the kind of issues we have with the transmissions.
Old Oct 19, 2012 | 12:22 AM
What makes you suspect I have a gasket leak on the pan? I never leave a drop of fluid on my garage floor.
Manning95444
Oct 6, 2012 09:18 PM
xxtheshockerxx
Jan 4, 2012 03:15 PM
RocknSS04
Feb 10, 2008 11:36 AM
