1st Gen ('70-'72): Rear End/ Gears
Old Apr 9, 2016 | 10:50 PM
AG_Monte71's Avatar
Default Rear End/ Gears
What's the quickest and easiest way to tell which gearing I have in my rear end. To my knowledge it's original. 1971 Monte... thank you in advance!
Old Apr 17, 2016 | 06:27 PM
monte07's Avatar
run the vin or if you still have the cars info like the book it should give you a better understanding. what engine did it originally come with and also the original transmission it also would give a general idea. with my mercury it came with a tame 4.6 4r70w 8.8 irs but it came with three tame and a getty up and go gears. 1.) 2.63
2.)2.73 (3.)2.83 (4.)3.11 as a last. a true way is to do a gear fluid change on taking the back off and looking at the gear its self or there should be a templet on the door jame saying what general power train could come with for that year
