Question...
Old Jun 14, 2009 | 12:25 PM
03Monte's Avatar
Default Question...
Hi,
I have a few questions that the community here might be able to answer for me.
First of all, let me give a little history. I have a 2003 Monte carlo SS that i love, i have always wanted to make this car into a beast, i only lack the skill to do it myself...
want to have the L67 top swap done, and maybe change out/ upgrade a few other part while the engine is dismantled.
Currently the car has some transmission issues, but before i pay to rebuild i want to see if a swap out to a 4T60-E HD may be better...
Now for the question!
I have two options as far as i can see, either drop in a complete L67 power plant, or make the alterations to my current engine, and drop in a 4T60-E HD trans (or rebuild my current)
Which would be the better rout to take and why?
Also, if i dropped the 4t60-e HD trans into my current 3.8, without the mods will it run, will there be any adverse effects?
Old Jun 14, 2009 | 01:01 PM
Welcome `03Monte to the MCF Family.
Tell us more about your Monte, and how many miles or
present mod's.
Check back later to see what our Expert Tech MotorHead
member's post/suggest the best way for you to proceed.
Look 4ward to knowing what you decide to do.
Sure hope one of our Member's will be able to
assist with your decision.
Good Luck
Old Jun 14, 2009 | 04:57 PM
03Monte's Avatar
present mod's.
Good Luck
Thanks KidSpace, my monte is stock w/ 65k miles.
Thanks
03Monte
Old Jun 15, 2009 | 07:55 AM
Good call, best bang for the buck mod for a NA 3800 IMO!
The s/c 3800s came with the 4t65HD if that is what you mean. If you have a 3800, you should have a regular 4t65 now. There is little difference between the two. The only real strength difference is the differential, otherwise, they're almost identical. For a basic top swap + bolt ons 3800, a regular 4t65 will be fine (or you can do the HD upgrade later for fairly cheap- its just removing the diff cover and diff).
Depends on the condition of your engine. Personally, I wouldn't have the trans rebuilt- I'd try to find a low mileage used stocker and swap it in (should be a lot cheaper)- though it kinda depends on the issues you're having (it may be a simple fix).
As for top swap vs L67 complete swap, it just depends on the shape of your bottom end. A top swap is usually a good bit cheaper (especially since you can buy the parts one at a time to fit your budget if need be), but there is no sense putting it on a bottom end thats damaged. With only 65k, I'd think a top swap would be the better route. You'll make more power due to your higher compression.
Also, if i dropped the 4t65-e HD trans into my current 3.8, without the mods will it run, will there be any adverse effects?
Bad idea, the 4t65HD has a 2.93 final drive compared to your current 3.29 final drive ratio. The gears are the same but with essentially a different 'rear end' in it, so the shift points will be wrong.
To do a top swap, you'll need a modified pcm anyways, so you can have it tuned either way.
Old Jun 15, 2009 | 08:03 AM
Member Bump'in96Monte
`Chad,
Thank You for sharing/posting/helping New Member 03Monte
and also other member's like myself that learn
from all your Posts Information.
Thank You ~ 4-Sure
Old Jun 15, 2009 | 08:27 AM
When you are working with the 4t65e-hd transmission, don't you have to upgrade your passenger axle also?
x2 on finding a cheap transmission and just fixing that one up a little and putting it back in. I saved myself around $1200 by getting a used transmission over a rebuild. and it came with a warranty too.
Old Jun 15, 2009 | 08:53 AM
03Monte's Avatar
Thanks guys for your honest answers, i DO appreciate it!
So what im hearing is, drop in a used 4t60 trans, and do the top swap...
my only concern is labor costs, and tuning (neither of which i can do myself...)
maybe i should just buy a 72 Monte and drop a 572 crate motor in (i dream big!), and leave my current Monte alone (except trans).
Old Jun 15, 2009 | 09:21 AM
NO! 4t65e... 65 65 65 65 65!! 60 is old style.
Check clubgp.com/newforum and look in some regional sections.
Old Jun 15, 2009 | 11:20 AM
03Monte's Avatar
Another question.
If i wanted to buy the parts to do the top swap piece by piece, where would you recommend to buy from?
Old Jun 15, 2009 | 11:58 AM
Moradpartscompany.com
or
Clubgp.com/newforum
