6th Gen ('00-'05): Pulley Size/Injectors
Old Sep 24, 2012 | 09:32 AM
Yellowjacket's Avatar
Default Pulley Size/Injectors
Ok so I have a question. I am trying to figure out what size pulley I can drop down to on stock L67 injectors. The fuel pump is upgraded and has the re wire as well. Also what size pulley would b safe with no intercooler? I have a cold air intake, headers, high flow cat, electronic cut out right after cat, cam, upgraded springs and rollers. Right now I am running a 3.3 with no problems. Just dont want to drop down if the fuel system or anything wouldnt be able to handle it.
Old Sep 24, 2012 | 10:08 AM
Proper dyno shops and such should be able to find out how much fuel you are pushing and whether you are close to maxing your injectors
How are you tuning?
Old Sep 24, 2012 | 10:14 AM
I dont remember what it read when it was dyno tuned awhile ago. i know at that time my fuel was maxed out which is why i upgraded the fuel pump and wires. but havnt dynoed it since then. Use HP Tunning
Old Sep 24, 2012 | 10:21 AM
In HPTuners look for the IDC% (injector duty cycle)
If you are at 90% or above, you are really close to maxing out the injectors and should move up.
Old Sep 24, 2012 | 10:35 AM
Ok cool thanks. Thats good to know.
Old Sep 24, 2012 | 10:40 AM
Also if I do upgrade the injectors do I need to upgrade the fuel rail as well?
Old Sep 24, 2012 | 10:46 AM
You shouldn't have to do the rail, just have to retune the car for the different injectors
Old Sep 24, 2012 | 11:10 AM
Ok sounds good. I might just do both since I'll be right there. Depends on cost. Does changing the fuel rail actually do anything or is it just for looks?
Old Sep 24, 2012 | 11:18 AM
Pretty sure it's just for the look, but there could be benefits that I don't know.
Old Sep 24, 2012 | 01:19 PM
Ok so for the injectors I am going to order them from ZZP but idk which connector they use. any idea? The picture below shows the different styles you have to pick from.
Attached Thumbnails Pulley Size/Injectors-injectors.jpg
