plug in scanner. DONT WORK.. HELP
Old Apr 19, 2012 | 01:28 AM
gtpshawty's Avatar
come one guyss.. any more suggestions?
Old Apr 19, 2012 | 07:34 AM
03SSLE's Avatar
I realize it is obvious and pretty basic, but you are turning the key to the ON position after plugging the scanner in, right?
Old Apr 19, 2012 | 11:06 AM
you may want to check the port on the car. My old car had a few corroded tabs on it. Just a thought.
Old Apr 19, 2012 | 01:48 PM
gtpshawty's Avatar
yea i turned the car on.. it still said no data link.. and i will check the tabs on the plug in
Old Apr 19, 2012 | 07:59 PM
monte07's Avatar
one of two things is the bcm is getting ready to take a dump or the obd II conection is needing to be cleaned. mine did the same thing and then the bcm finnally took a dump. be very carefull and treat it as a tuchy thing because it can be going with out any warning than what you have.
Old Apr 19, 2012 | 09:59 PM
gtpshawty's Avatar
and thats the one in the trunk right
Old Apr 19, 2012 | 11:00 PM
The Body Control Module is under the dash in an 04. I'm not sure about the 03 but i think its the same.
Old Apr 19, 2012 | 11:58 PM
gtpshawty's Avatar
thankx.. but what is the thing that goes on the driver side in the trunk... its an 03 ss le
Old Apr 20, 2012 | 12:05 AM
could be your onstar crap?
Old Apr 20, 2012 | 10:02 AM
gtpshawty's Avatar
ok cool.. one more thing.... while im on it.. my bro has the car in okl so i cant check it right now... but his wheel hub making a ****ty sould like something engadging and getting stuck... from the drivers side... and the abs light shoot on and stays on also traction device messing up too all can be caused by bcm?
