Please Help Shaking at 2500 rpm
Old Mar 27, 2007 | 01:31 AM
brockafella's Avatar
Default RE: Please Help Shaking at 2500 rpm
Thanks for all the input. I'm on it and will let you know what ended up being the problem.
Old Mar 27, 2007 | 07:52 PM
speedjunkie's Avatar
How do you normally accelerate from a stop? Easy to just below mid? Reason I ask, I've seen a coil pack to the same thing. Light acceleration is fine, little more gas, stumbles, floor it, cleans up. You can troubleshoot with a known good one if you have a buddy with one, or will let you borrow one. They're not too tough. Just a thought. Good luck.
Mike
Old Feb 25, 2009 | 10:50 AM
Well it has been awhile since I posted here but did figure out what the problem was. I ended up doing a BG service on the intake or injectors and one for the transmission. Did not solve the problem unfortunately. A few weeks later I came out and the car was dead. Bought a new battery and the hesitation has not returned and it has almost been 2 years. So either a weak battery was causing this or when I disconnected the battery it reset something in the computer. Anyway thought I would post this because it was driving me crazy when it was happening. Late
Old Feb 25, 2009 | 10:54 AM
kweef's Avatar
hmm odd fix. weak battery causes failed spark? interesting thought
minicupracer1
Apr 25, 2015 05:39 AM
green98
Jan 24, 2015 04:37 PM
skylark65
Feb 19, 2010 05:14 PM
kruqnut
34
Sep 20, 2009 05:34 PM
BeachBumMike
Sep 20, 2007 08:49 PM
