picked up a supercharger
Old Sep 2, 2013 | 03:50 AM
killerBee's Avatar
Default picked up a supercharger
Picked up a supercharger on CL for cheap off a 2000 grand prix gt supercharged.
My question is can i drop it on my 2003 Monte Carlo SS na supercharged serious 2 motor. If so what wheel i need?Thanks for the help.
Old Sep 2, 2013 | 04:04 AM
not sure if you can drop it on a serious 2 motor or wheel you'll need but hopefully another member will be able to help........
Old Sep 2, 2013 | 07:40 AM
LW57912's Avatar
Yes you can however you are going to need a lot more than just the supercharger. Its called a top swap so do a search on that there are tons of threads out there.
You'll need all of this off a L67 supercharged 3800 (I'm probably forgetting stuff too)
Heads
Lower Intake
Throttlebody
Fuel rail
Injectors
Crank pulley
Idler and tensioner pulley for the SC belt
Then you'll need gaskets and fluids to complete the swap. This is also a good time to do other upgrades while you have the engine apart like headers, rockers or a cam, etc. This will really help reduce KR.
You may need injector connectors depending on what your car has. I needed them on my 2002. You'll want to run a colder tstat and colder plugs, and you'll need your PCM tuned.
Old Sep 2, 2013 | 09:03 AM
turbo monte's Avatar
^^ this is correct, also search "top swap" and there is tons of reading on this subject... good luck and congrats of buying the SC!!
Old Sep 2, 2013 | 10:47 AM
killerBee's Avatar
Do u guys think it is worth dropping one on. What kinda power wheel i gain?
Old Sep 2, 2013 | 11:41 AM
LW57912's Avatar
I'd say its worth it for sure if you want to do a build other than a turbo. My only regret was I didn't do a cam and heads at the same time.
You'll get about 50hp at the crank. So you'll be around 250hp or 200hp at the wheels. Its a noticeable difference, but like I said before do some other exhaust/valve train mods while you're there.
Old Sep 2, 2013 | 11:53 AM
killerBee's Avatar
Ok cool, i agree. Im do a few other things like port & polish intake and heads .
If got any other ideals.Please let me kno
SIC LSX
Jan 18, 2010 12:02 AM
bumpin96monte
Nov 3, 2009 09:35 PM
aussiek2000
Jan 11, 2009 11:16 PM
m0nt3c4rl0fr33b1rdSS
Jun 25, 2007 02:03 PM
Seanzy
Jun 5, 2006 04:29 AM
