"PCM CASE Learn Procedure"
Old Nov 25, 2010 | 07:15 PM
Crusader SS's Avatar
Default "PCM CASE Learn Procedure"
Good evening all, quick question for you... I had my INTENSE PCM installed about a year ago and they did not do a "CASE Learn Procedure"... I was browsing the "INTENSE" website and noticed that they recommend doing it for my 2002... My question is, what improvements does this procedure bring if any?... I'm going to visit a dealer and have them do it anyway, just curious as to why?.. Thanks,
Old Nov 28, 2010 | 02:44 PM
06MonteSS's Avatar
yes, you should absolutely do it! Not running the relearn procedure can cause idle and performance issues...
A CASE relearn is needed when you replace your original PCM (or the actual crank sensor). The vehicle is driveable without the relearn though you will usually get an SES light. The CASE relearn can only be done with the PCM installed in the vehicle in which it will be used. It's a way for the computer to learn a parameter (Crankshaft Angle Sensor Error) that is unique to each particular engine.
The core program from PCMforless/Intense is probably the most common reason you'd need a CASE relearn since you're permanently replacing your original PCM with a tuned PCM.
If you have access to a GM TechII scan tool here is the case relearn procedure:
Connect a scan tool to make sure there are no trouble codes stored in the computer’s memory. If there is any power train trouble code other than P1336 (Crankshaft Position Variation not learned), the computer will disable the relearn function until the problem that aused the code has been eliminated. Also, make sure that the engine coolant (check it when the engine is cold) and oil levels are at an acceptable level.
1. Set the parking brake and block the drive wheels. Make sure that the hood is closed.
2. Start the engine and make sure that the engine coolant temperature is at least 158 degrees F. (70 degrees C.)
3. Turn the engine off for at least 10 seconds.
4. Select the crankshaft position variation learn procedure (CASE Learn)on your scan tool.
5. Make sure that the transmission is in Park. Start the engine.
6. Apply the brakes and hold the pedal firmly.
7. Follow the scan tool instructions.
Remember: That you are going to increase the engine speed to approximately 3000 RPM, 4000 RPM, or 5150 RPM. That’s the variation learn fuel cutoff RPM (depending upon the engine), and that it’s important to release the throttle when the engine RPM starts to decrease as a result of the fuel cutoff going into effect. Failure to do such will result in over revving of the engine, causing possible engine damage.
8. Once the engine has returned to idle, check the status of Diagnostic trouble code P1336. If the scan tool indicates that the CASE has been learned, the relearn procedure is now complete. If CASE has not been learned, check for the presence of other power train codes. If any exist, correct the problem, then repeat this procedure.
Old Dec 12, 2010 | 10:36 AM
Thanks for the info... I will definately have this done... When I visited the dealer they told me that unless a warning light is on, then don't bother, and I left ... I will be going to a different dealership to get it done... Thanks again...
RickCoMatic
FWD Tech Guides '95-'07
31
Jun 14, 2024 05:29 PM
adryan16
Sep 19, 2012 11:27 AM
86 luxury sport
Jun 6, 2011 02:41 AM
knightfan26917
Mar 26, 2009 09:51 PM
zipsayain
Jul 31, 2006 03:39 AM
