P-log?
Old May 6, 2008 | 08:38 PM
tlip06's Avatar
Default P-log?
I have an 04 sc ss with minor mods and I keep reading about these p-logs but dont know much about them.
If I were to get this mod would I get the front one or the rear?
Is this a mod that is simple to install?
Old May 6, 2008 | 11:19 PM
Default RE: P-log?
You only get the front. Basically, it is just a front header if you will. Your stock rear manifold is a pretty well designed tubular steel piece, as is the crossover. Your front exhaust manifold is cast, and is pretty restrictive where the 3 pipes converge. It is also extremely difficult to port enough to make good gains, so they decided to make a tubular steel front manifold similar to the stock rear. I think they do a pretty good job describing it on their site:
http://www.zzperformance.com/grand_p...&catid=110
Its cake to install, took me less than a half hour- probably one of the easiest bolt ons you can find. You can see for yourself how easy it is- pop your hood and look at the front exhaust manifold (has the silver heat shield over it)- you can see the two bolts at the crossover flange on its outlet, and the 6 bolts holding it to the head- everything is right there.
It depends how far you want to go and if you've already done a downpipe. If you want to keep going, and haven't done a downpipe yet- you should think about headers. They're cheap enough now that its getting to be worth it. Personally, I got my plog off clubgp used for stupid cheap, so it was hard to pass up.
Old May 31, 2008 | 07:08 PM
04 Intimidator's Avatar
Default RE: P-log?
Well worth the money.
Old Jun 1, 2008 | 12:34 AM
2000_BLACK_SS's Avatar
Default RE: P-log?
ORIGINAL: 04 Intimidator
X2
rj
Jul 28, 2010 10:52 AM
2003supersport
May 16, 2009 02:07 AM
sickofsoyo
Feb 24, 2008 09:20 PM
