6th Gen ('00-'05): Over heating 3400 sometimes
Old Dec 13, 2014 | 08:53 AM
Bait's Avatar
Unhappy Over heating 3400 sometimes
Hey guys and gals,
I decided to come here for an answer instead of facebook. lol
My 01 3400 has 163xxxmi she is my daily so I do depend on her and am not prepared to purchase a new car.
She has started to warm up on me lately to the 3/4 mark. As soon as I put on heat she will come down to normal temp., the issue at hand is the air is cold. I do get warm air in there at times too.
Did a flush and fill after the water pump was changed a few good months back, mid to late summer. Prior to changing the pump I had aused stop leak till the part came in to fix it. When it first warmed up'd on me a few weeks back I checked the fluid. I used the quick release cap and once I pulled the cap off it steamed a little bit. Problem mostly went away, thinking it may have been an air bubble.
I checked again yesterday and it was almost a gallon low on coolant fluid, naturally I checked the oil immediately and nothing mixed in there.
Is there a blockage, new thermostat, new head gaskets new car?
Any help is appreciated.
Old Dec 13, 2014 | 08:58 AM
I would guess air in the system... sounds like you're low on coolant because it's not being flushed properly, then it finally gets pulled into the system so it seems like it's gone.
PS - I came here via FB
Old Dec 13, 2014 | 09:01 AM
Hi `Bait,
It sounds like it could be a bad thermostat ? Did you put a new one in when you did the flush & water pump ?
*(I don't like stop leak products, unless it's an emergency)
Check back on your thread & see what our more expert member's posts on your problem > Good Luck<
Old Dec 13, 2014 | 09:58 AM
Bait's Avatar
Originally Posted by Space
Hi `Bait,
Ya i had to use it. =/ work school and only car. The leak was on the water pump gasket so I replaced the whole thing.
The issue seems worst when colder out.
The thermo in the 3400 is a pain, looks like my next step along with a professional flush.
Old Dec 13, 2014 | 10:00 AM
Bait's Avatar
My buddy that always works on cars did it. He has been reliable. But that is what leads me to the Barrs stop leak. It is all over my radiator cap when I pull it off.
Old Dec 13, 2014 | 10:25 AM
Hi `Bait,
Maybe (?) the below links & vid's may help ?
I hope your friend can help repair @ a low cost > Good Luck<
www.youtube.com/watch?v=ZgLWR1dCXRM
Dec 20, 2010 - Uploaded by richpin06a
GM 3.1L,3.4L Thermostat Replacement. ... I have a 1999 ChevyLumina. The thermostat housing bolts will not move at all! I tried pb blast and ...
► 7:07
www.youtube.com/watch?v=sixrnFwNq-U
Jul 10, 2011 - Uploaded by MichiganFlyer2
make sure to have the ignition off when you disconnect/reconnect the sensors. Do not reuse gaskets. Do not ...
► 30:25
www.youtube.com/watch?v=9r1dSsX510g
Feb 1, 2012 - Uploaded by sergey.atlanta
Replacing the thermostat on Chevy Venture, aka Pontiac Montana, Trans Sport, aka ... And many other GM ...
How to Replace a thermostat on a GM 3.1L or 3.4L automobile
diy-auto-repair.wonderhowto.com/.../replace-thermostat-gm-3-1l-3-4l-a...
Aug 25, 2011 - Replace the thermostat on your GM 3100 or 3400 vehicle with this nifty tutorial. The video shows you how to replace a thermostat on a 3.4L GM ...
Part 1 -How to Test the Thermostat (GM 3.1L, 3.4L)
troubleshootmyvehicle.com › GM › 3.1L, 3.4L
Aug 27, 2011 - Location of Thermostat on the 3.1L and 3.4L GM engines ... total pain in the neck to replace it... so testing it to make sure it's BAD ... 1987, 1988, 1989, 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005.
Replacing thermostat in 3.4L without removing exhaust cross over ...
chevroletforum.com › ... › Current Chevrolet Car Models › Impala
Jan 9, 2010 - 5 posts - ‎5 authors
Decided to post in this forum as well since same engine is used in Impala's Below is how I replaced the thermostat on a 2004 Chevy Monte ...
Diagram locating thermostat on 2001 Chevy Impala 3.4 L ...
www.justanswer.com › Chevy
Engine Coolant Thermostat Replacement (3.4L). Tools Required. J 38185 Hose Clamp Pliers. Removal Procedure. Remove the air cleaner intake duct. Partially ...
Old Dec 13, 2014 | 10:51 AM
Bait's Avatar
Thanks space for the research.
Old Dec 13, 2014 | 11:01 AM
You're Welcome, I hope it helps + I hope some of our expert tech member's that have done this also post their advice/comments...Good Luck on resolving this issue
Then it's time 2 `Party `if there's any $'s remaining
Ask `Santa 4 $'s this year (lol)
Old Dec 15, 2014 | 03:14 PM
Bait's Avatar
I am ashamed to say that she was very thirsty, she downed a gallon.
I have also replaced the radiator cap also and have not had an issue as of yet.
Now to determine which thermostat I would like to get...hmmmm
Rockauto Both 180
ACDELCO Part # 12T55D More Info {#19161951}
MOTORAD Part # 2067180 More Info {#65678} High Flow
oneandonlydylawn
Jun 2, 2013 02:15 PM
MJClemm
Oct 26, 2012 05:50 PM
connersdad19
May 29, 2009 03:24 AM
sprfrk2005
May 20, 2009 09:15 AM
bjar61
Jan 7, 2009 04:48 PM
