Okay, I give up....Where is the oil filter?
Old May 15, 2007 | 04:53 PM
GrandPaDave's Avatar
Default RE: Okay, I give up....Where is the oil filter?
ORIGINAL: 04 Intimidator
ORIGINAL: SolaraSlayer
[align=left][/align]
GPD'S DO-IT-ALL TOOL[align=left](ONE TOOL TO RULE THEM ALL)[/align]414 - 14 inch NUTBUSTERâ„¢[align=left][/align]
SKU : 414
PRICE : 25.90
(I thought that was a cool trademark, actually the v-jaws work better)
Bahh!!! $1 Used 12 inch flathead screwdriver. Hit the side of the filter till you pierce it and go all the way through. Then just twist. I did that on some 70's and 80's vehicles, not sure if I'd have room now.
When you replace the filter though, 1. avoid Fram - just do a websearch to see how much they fall apart. 2. put a small bit of oil on the gasket with your finger and it will come off easier next time.
LOL!! I was going to say, just stab it with a screwdriver if you have a large oil catching pan. I can't believe someone else uses this method. You must have been born in the 50's like me.
Old Oct 5, 2008 | 02:47 AM
biggriggs's Avatar
Stabbing the filter with a screwdriver is how I learned, and that was circa 1996. It's tried and trued, and easy.
Old Oct 5, 2008 | 09:51 AM
RocknSS04's Avatar
Agreed on the Fram filters! Get one made by Wix. Several brands available, such as NAPA Gold, or even Car Quests brand.
Old Oct 5, 2008 | 10:58 AM
Snyderman's Avatar
I just had the ordeal with mine. Mechanics gloves got the original out, now I use K&N filters cause they are super sweet, and they have a 1" nut on the top, perfect for removal from the 3.9 with a regular socket.
Old Oct 5, 2008 | 06:28 PM
God_Bot's Avatar
I actually laughed out loud at the title (no offense meant). I was used to changing the oil in our pickups or suburban, had to twist your hand and tilt the filter and go through a maze on one of the pickups. And of course it was that pickup that I drove the most. Anyway it took me awhile to find the filter on the car too, dad finally got underneath and came up laughing at me. The 3.9 filter is right next to the drain plug, nice spot even if it's a little tight for a filter wrench.
Old Oct 10, 2008 | 06:54 PM
04 Intimidator's Avatar
OMG I can't believe how old this thread is. To answer and old question, I was born mid 70's. This is the way my dad showed me on a stubborn Olds that hadn't had oil changed in like 3 years and was full of sludge.
rj
Feb 6, 2008 05:31 PM
rj
Feb 2, 2008 07:32 PM
rj
Nov 11, 2007 02:33 PM
mymonte
Nov 22, 2006 10:50 PM
Soulja
Sep 27, 2006 03:52 AM
