Oil useage/burn off.
Old 10-22-2010 | 07:30 PM
7498MonteCarlo's Avatar
Photobucket
Monte Of The Month -- August 2010
Default Oil useage/burn off.
My 98 MC, stock 3100, seems to use a lot of oil. I use Castrol GTX High Mileage 10W30, and on average, I have to add 1.5-2 quarts in between each oil change. Does anyone elses use this much oil?
Note: the car does not leak nor does it burn off out the tailpipe.
Old 10-22-2010 | 07:51 PM
MillerMonteSS's Avatar
2010 Monte Of The Year
That seems a little excessive to me. I think you should consider a compression check. If the oil gets burned completely enough by the catalytic converter, you may not see it coming out the tail pipe. Good luck!
Enzo354
04-09-2012 03:40 PM
00montegc
08-30-2011 09:46 PM
05-10-2011 10:10 AM
04-16-2010 10:20 PM
Aaron_Provost
12-13-2007 11:05 AM
Quick Reply: Oil useage/burn off.
