oil psi question
Old Sep 14, 2009 | 07:12 PM
scc24540's Avatar
Photobucket
Default oil psi question
does anybody have any idea what would make the oil pressure in my car suddenly go up? its a mechanical guage and i have used a 2nd one just in case so its not a guage problem. i used to idle at 25ish psi and now i idle at 40-42psi. if i go W0T i hit almost 80psi and cruizing at hwy speeds im pushing 60+ psi. any ideas what would cause this?
Old Sep 17, 2009 | 01:42 PM
scc24540's Avatar
Photobucket
bump hoping for a answer
Old Sep 17, 2009 | 01:44 PM
as far as I know if it's not the gauge then oil pressure goes up because of some kind of blockage in the system. and the car is pushing more at it to try to get it through.
How's your oil filter? And are you using 5w-30? How's your oil pump itself?
Old Sep 17, 2009 | 03:31 PM
MAMONTE's Avatar
Could the sensor be bad? My mom's Bonneville was registering 0 oil pressure, and it was the sensor...
Old Sep 18, 2009 | 07:44 PM
scc24540's Avatar
Photobucket
Originally Posted by scc24540
d its a mechanical guage and i have used a 2nd one just in case so its not a guage problem. this?
i dont have a sensor...
Old Sep 21, 2009 | 12:07 PM
scc24540's Avatar
Photobucket
problem solved
Old Sep 21, 2009 | 12:14 PM
MAMONTE's Avatar
What Was It?
Old Nov 30, 2009 | 11:02 AM
RussellUCF's Avatar
Default Oil Pressure Gauge issue
As I went to change my oil pressure sensor this weekend, i noticed the line was cut. It was a clean cut and i had enough line to splice them together with a wire clamp. I also changed the oil pressure sensor because I thought that is why the gauge was intermittent...I figure while I was down there I might as well change it...Not just splice the line...
Well, now the gauge works 8 out of 10 times...a few times now the oil pressure gauge on the instrument panel doest tell me the Oil pressure. It doesnt pop on like it normally should.
can someone tell me what may be the problem???
New sensor- spliced wires were tight when I left it...(maybe thats the problem, it needs to be connected better)...
any tips would be great...
surprisingly, the oil pressure gauge would work even with one wire still connected (only every now and then, not consistent though).
Old Nov 30, 2009 | 11:13 AM
It's a long shot, but the actual gauge itself could be going bad on the instrument cluster.
Sometimes people's speedometers go bad, sometimes the tachometer...
Old Nov 30, 2009 | 02:43 PM
monte07's Avatar
did you check every thing as well as the gage? what i mean the wires corect oil level on dipstick things like that? also keep us informed on what has been done so far
jcoeracing97
Nov 16, 2011 07:24 PM
z34phoenix
Oct 31, 2011 09:02 AM
magnnuss_75
Jan 14, 2009 11:20 PM
fxdrider
Oct 1, 2007 09:39 AM
06LT3
Jul 18, 2007 10:05 PM
