oil leak
Old Nov 17, 2007 | 04:31 AM
jay26's Avatar
Default oil leak
i seem to be loseing a few drops of oil over a 24 hour period.have yet to really get under and inspect,any suggestions?
Old Nov 17, 2007 | 08:23 AM
Default RE: oil leak
[align=center]
ORIGINAL: jay26
[/align][align=center]Let me see, I'll look in2 my Crystal Ball : )[/align][align=center][/align][align=center][/align][align=center]Hi `Jay,[/align][align=center]First suggestion Get under your Monte & check [/align][align=center][/align][align=center]1. Place cardboard under car, and pinpoint the area[/align][align=center]2. Check oil pan gaskets/oil filter area.[/align][align=center]3. Smell fluid to determine if it's motor`oil, or transmission fluid[/align][align=center](trans fluid should have a red tint)[/align][align=center]4. Check engine area: P.S., brake lines etc.[/align][align=center]5. Check valve cover gaskets.[/align][align=center][/align][align=center]Good Luck, & let us know `ok[/align][align=center]Some mechanic's will check `free, & give you an estimate.[/align]
Old Nov 17, 2007 | 09:23 AM
Cowboy6622's Avatar
if its oil, check the drain plug area too. i had this happen to me once and i had not put the draing plug back in quite tight enough. the last time you put it on, did it go on easily or hard? if it went on hard, something was wron,g and you probably cross threaded and that will usually make it leak. check the oil filter for a hairline crack as well. watch your mirror next time you drive and just floor it once for about 5 minutes, see if any smoke is created behind you... thats what a friends car did once when it had a crack in the oil filter.
Old Nov 17, 2007 | 01:00 PM
jay26's Avatar
thanks im gonna check it out in a few right now the game is on.i did do the cardboard,but i checked again no oil,anyway i'll look into it
Old Nov 17, 2007 | 02:43 PM
Cowboy6622's Avatar
sorry, in my last post where i said 5 minutes, i mean't 5 seconds [&o]
Old Nov 27, 2007 | 11:23 PM
monteman1978's Avatar
Oil leaks, do not worrie about it until u can empty an oil pan in 5 days than u got issues. LOL I am at that point right now.
Old Dec 1, 2007 | 07:04 PM
04 Intimidator's Avatar
We really need a CAR heading under our profiles.
What year and engine are you running? How many miles?
I would clean the area around the heads and valve covers to see if you can find oil coming off the block somewhere. Otherwise you might be burning it. If so, I would switch to synthetic right away.
MonteSquarlo
Dec 16, 2012 06:18 PM
dabeav3
Dec 11, 2007 09:43 AM
ttop86ta
Nov 28, 2007 01:10 PM
97Z34FAN
May 21, 2007 12:19 AM
lateralex426
Feb 5, 2007 08:57 PM
