6th Gen ('00-'05): Oil change
Old May 15, 2022 | 11:45 AM
frankboni's Avatar
Default Oil change
I own a 2003 Monte Carlo SS, 3.8 engine, with 160,000 miles. I need to get an oil change, but I cannot find a facility that has Castrol 10W30 on hand, which was what was used for my last oil change. What would be a good substitute that would be good for the engine, and be readily available at most oil change facilities? Thanks.
Old May 15, 2022 | 09:24 PM
Not all oils are the same, but you can comfortably use any of the leading brands (like Valvoline, Castrol, Quaker State, Mobile1). I believe GM actually calls for 5w30 (but I know you can also run 10w30 without any issues).
I know some people who have gone the extra mile on research with oil and have resulted in loyalties to them. But honestly, for a daily driver that gets regularly scheduled oil changes (despite the oil life monitor, I always change every 3000-5000 miles) it should be fine.
Old May 15, 2022 | 09:36 PM
Onion39's Avatar
I've always used Pennzoil Platinum high mileage synthetic, and also the Valvoline synthetic blend high mileage. There's really no right or wrong.
Old May 16, 2022 | 08:08 AM
The earlier 3800s did have 10w-30 on their caps, but GM did change the recommended oil to 5w-30 and you are fine to use.
I always use Mobil 1 in my vehicles.
Old May 16, 2022 | 04:17 PM
I'm 100% in this boat. For a daily driver, get a major brand oil that's API certified, change it regularly, and don't worry about it. Its near certain at that point that the car will end up in the junkyard for some other reason than oil caused problems / wear (body rot, wreck, blown trans, etc etc).
No offense to those who have suggested brands, but IMO I'd take suggestions about one brand being superior with a grain of salt. Most individuals don't have the time or equipment to fully test several oils head to head in controlled test situations. There is tons of good test data out there if you're really interested in that info, but IMO its not 1900 anymore - bad oil prematurely wiping out bearings or causing parts to seize up due to poor properties is incredibly rare, so finding one brand that's a couple percent better at some specific test than another is irrelevant to the average user.
Old May 17, 2022 | 08:11 AM
Jason has my car with a 22 year old engine with over 200,000 miles on it and when he took it apart he said it was cleaner than his blue Monte that has less than half the mileage
But yes, routine maintenance is the key.
Old May 17, 2022 | 10:59 AM
I didn't mean any disrespect at all by that.
My main point is just that the average consumer really has no good way to truly test several oils head to head to be able to objectively show 1 specific brand/type of oil is superior to others in its category. I believe that for the typical car owner that there are several types that will allow the engine to exceed the life expectation for a car as a whole these days.
The tough part is variability - virtually no one has 2+ identical cars with near identical usage and is willing to tear the engine all the way down at some final interval for wear component comparison. Even for someone that has that unusual scenario, theres still the added variability of manufacturing tolerances being slightly different engine to engine. Theres also the variable that people take a long time to accumulate enough miles to significantly wear an engine and over that time the oil additive packages can change as specs are updated so you may not be testing the same oil formila at mile 100 as at mile 200,000.
IMO true comparison testing to show an oil is superior to others is best done on test fixtures that simulate specific systems of a real engine to weed out ALL of the variability and yield an objective/numerical output at the end. The aggregate result of several iterations of several types of tests can then begin to show if an oil is truly adequate (and which performs better).
Luckily for the average consumer / daily driver, theres no need to bother worrying about any of that stuff as API already does all of the legwork to prove that an oil is good to go. Certainly its not applicable in every case (say for a race car or someone shooting for a million miles), but its good enough for the vast majority of cars on the road thatll end up in the junkyard by 250k or less. No doubt there are some brands independently proven to be slightly better at X, Y, or Z but I really dont get the feel that those translate into real world improvements that actually matter to the end user (ie brand X made it to 600k miles before showing unacceptable bearing wear, but brand Y made it to 750k - meanwhile the car rusted through the floorboards and ate 3 transmissions by 250k).
Old May 20, 2022 | 10:39 PM
@bumpin96monte I am going to bet @ChibiBlackSheep is going to agree with your statement. On a car that is a daily driver, that odds are would rot away before an engine failure due to variables in oil, routine maintenance is key. It is just funny I am able to compare two similar vehicles at the moment.
But, I will say, I have seem some things with Chibi's old black Monte that has over 200K vs my blue Monte that to this day does not even have half that mileage. Especially with coolant!!!
These pics are of my 2004 Blue Monte taken in 2011 with 64K miles on it. At the time this was done, car was bone stock. I tore the original Lower Intake out to put in a donor one I port matched.
And then these pics are from 2014 with about 70k on them and the lower intake that was clean enough to eat off of a few years earlier (I was doing a L26 UIM swap).
Now present day on the blue Monte with over 90k miles. I really don't have good pics, but the oil gunk on the head around the valves and such looks a bit thicker on the blue Monte (the area that is the best tell-tale is the bolts for the head, the ones on the blue monte are covered in black oily gunk where the black monte is not covered in gunk, oddly the heads of the bolts for the heads actually look like some surface rust on the very top, one could argue "is the oil not bonding right" or "is the oil not gunking up during use").
Old May 20, 2022 | 10:48 PM
And now, all of these pics are from the 2000 Black Monte, present day with about 203k miles. From what I understand from Chibi, none of this has ever been opened up before.
Old May 21, 2022 | 10:11 AM
The valve covers were removed before, because I did the ER Rockers. But yes, I never did go down to the LIM gasket on that car for it's whole life.
