Oil Change
Old Jun 28, 2006 | 02:26 PM
darion's Avatar
Default Oil Change
My change oil message came on so last weekend I went ahead and changed it. My question is that the message didn't clear and go away. From my understanding it would've went away on it's own. Was I wrong in this and need to do something to clear it or could it be a bad sensor?
Old Jun 28, 2006 | 03:50 PM
montejass's Avatar
Default RE: Oil Change
What year is your monte???
2001 - present require you to manually reset it. Search the forum for information related to resetting the change oil light as I am pretty sure we covered it.
Old Jun 28, 2006 | 09:00 PM
darion's Avatar
Nope, I looked and there was oil changes but I didn't see anything on how to reset the sensor and clear the message
Old Jun 28, 2006 | 09:17 PM
DESS03's Avatar
just tun you key to the on position and push and relase the gas pedal all the way to the floor 3 times
Old Jun 28, 2006 | 09:26 PM
schroederdion's Avatar
and if that dosent work (but it will), then read your manual becouse it tell's you how to reset it threw the stereo.... i read it once so it is there....
mstrmysterious63
Sep 25, 2012 03:04 PM
dcnaser
Mar 25, 2012 07:40 PM
drmrgal
Apr 8, 2011 05:11 AM
04MonteLS
FWD Tech Guides '95-'07
19
Mar 10, 2011 06:14 PM
70monte1
25
Jan 19, 2010 09:04 PM
