6th Gen ('00-'05): Oil cap/ breather a benefit?
Old 09-07-2012, 12:07 PM
Monroe's Avatar
Monte of the Month -- December 2013
Default Oil cap/ breather a benefit?
I've been looking around for minor things to make the monte really stand out n i came across a Oil Cap Breather. I was wondering, is there any benefits to getting one or will it send my Super Sport on a performance down-slide??
Old 09-07-2012, 12:12 PM
nitehawkjcb's Avatar
It will introduce a vacuum leak into the crankcase unless you have the PCV blocked off.
Old 09-07-2012, 12:27 PM
Monroe's Avatar
Ive been meaning to say this for awhile...whats a PCV? N is it really something u should be blocking off?
Old 09-07-2012, 03:50 PM
Positive Crankcase Ventilation valve. You don't need to block it off unless you're adding an intercooler.
Old 09-08-2012, 10:58 AM
I suggest you invest in an Oil Catch Can. I got mine on ebay; just a universal one for around $25-30. Cylindrical can with two b-a-r-b-e-d (wouldn't let me put the word in without it being censored for some reason lol) fittings, a visible vertical chamber for how much oil there is, and a gold screw-on top. It takes the oil-air mixture from your PCV valve after the blow-by, and "catches" the oil into the can, producing cleaner air back into your throttlebody and engine.
It produces a cleaner burn, and prevents and build up of oil and gunk in your upper intake manifold. After driving with it for a few months, am I glad I got one. It's almost a 1/4 filled with oil.
Old 09-08-2012, 12:54 PM
A breather is a bad thing, not a good thing. The people who buy breathers are those who bought an IC or something similar, and it blocks off their factory PCV system. You want to have a PCV system- you don't want to screw up a functioning one by adding a breather.
Old 10-22-2012, 01:40 PM
Here is how ya rock the "breather look", while maintaining the much-needed sealed effect:
K&N chrome push-in:
Filled beginning of breather with expanding foam. Modded into OEM tube, & "pinned" into place.
No leaks for me!
(For those who cannot tell, I run a Cold Air Inductions, Inc., cold air intake.)
Old 10-22-2012, 03:42 PM
zzapultimate's Avatar
K&N chrome push-in:
No leaks for me!
Rice
I've always wondered about this subject too.. glad to have it cleared up
Old 10-22-2012, 03:45 PM
I'm actually going to be running one next year when I do my CSC build...
Old 10-22-2012, 09:33 PM
No leaks for me!
Why a fake breather?
Quick Reply: 6th Gen ('00-'05): Oil cap/ breather a benefit?
