O2 sensor
Old Jul 20, 2013 | 07:51 AM
Bbgrant25's Avatar
Question O2 sensor
Hey guys I need some help. I have a 2001 monte ss 3800. I live in fl so no emission tests. I had a clogged cat so I cut it out now bank 1 o2 sensor shows bad I know it's not bad. I know it's cus I put a straight pipe in. I want to know can i reprogram the CPU so that it it dose not read bad?
Old Jul 20, 2013 | 08:34 AM
Yes you have to tune out the p0420 code from the pcm.
Most w-body vendors can do this. The_Maniac (Jason) also can help members with this.
Old Jul 20, 2013 | 02:12 PM
Bbgrant25's Avatar
Question
Ty I understand that part but how do I do it?
Old Jul 20, 2013 | 09:48 PM
To "tune out" the P0420 you need to have a device to reprogram the PCM. This is NOT a scan tool. The most common devices are a HPTuner and DHP PowrTuner. DHP is out of business and an HPTuner is rather pricy for just deleting a code.
There are tons of companies that will delete that code (and if you want, re-tune the PCM). None of these companies do it for less then $100.
I have a DHP PowrTuner and a device to allow me to use it with a PCM on a bench (so I can re-program a PCM in or out of the car).
Below is a link about my PCM services I offer:
https://montecarloforum.com/forum/pr...impalas-42773/
98Z34
Aug 7, 2011 01:24 PM
FLMONTESS01
Sep 11, 2010 11:47 AM
Endo
Aug 26, 2010 10:16 AM
The Rev
Oct 19, 2008 09:08 PM
rcohen
Feb 12, 2007 08:49 PM
