6th Gen ('00-'05): no heat
Old Oct 19, 2012 | 10:25 AM
Jason Block's Avatar
Default no heat
This might have been talk about before but. i have an 03 3.4 LS the intake gasket has been replaced along with t/stat,water pump. Well the problem i have is the 1st i drive it for the day i get a lil heat then it goes away and the temp gauge climbs to about 3/ 4 back to 195 but still no heat.I've noticed the return tube is cool I've flushed the heater core doesn't seemed plugged. I'm betting i have air in the lines. any comments will be help full thanks
Old Oct 19, 2012 | 12:09 PM
turbo monte's Avatar
first off: welcome to mcf.
possibly air in the lines, bleed the system to get all air out is the first place to start. did you flush the radiator out with a garden hose to get all the gunk out when the intake gaskets were changed?
Old Nov 5, 2012 | 09:29 PM
Sorry. took so long to write back. i reflushed the system still have the same problem the messed up part is that i really only have the problem in the morning at the end of the work day every thing works fine
Old Nov 6, 2012 | 07:01 AM
Sounds to me like a Tstat issue....
Working intermittenly....
prolly stuck open...if your not haveing any overheating issues....
Old Nov 6, 2012 | 09:06 AM
MarkIV396's Avatar
I had that problem on my 3.1 LS, The upper hose would collapse after you drove it a while.
I replaced the upper & lower & also found a glop of goo (Antifreeze) after I flushed it out...
Old Nov 7, 2012 | 02:50 PM
The messed up part is when u first drive it for the day. it might blow heat if it does a lily bit later it'll get cool then the temp gauge will climb
Old Nov 7, 2012 | 02:55 PM
Sounds a lot like a thermostat to me!....
Even if you replaced it beforre....they have no rhyme or reason to go bad....could have been faulty when you bought it!
Old Nov 8, 2012 | 07:58 AM
Thanks for the help ill give it a try
Old Nov 19, 2012 | 04:25 PM
Found out the problem headgasket was bad leaking 1-3 and water jacket to 2. thanks everyone that tried to help.
mymonte
Nov 22, 2006 10:50 PM
spike_monte
Nov 22, 2006 10:47 PM
CuttyKev
Oct 2, 2006 10:26 PM
USELESS
May 1, 2006 09:34 PM
mcarloss04
Nov 21, 2005 11:38 AM
