7th Gen ('06-'07): New Engine
Old Jul 20, 2015 | 01:40 AM
Kassius Skinner's Avatar
Default New Engine
Ok so im considering buying a new engine for my 2006 Monte Carlo 3.9L LT. I wanted to know if i bought the 2006 5.3 L engine would it fit in my car and would i need to buy other parts for it.
Old Jul 20, 2015 | 08:20 AM
Mels SS's Avatar
It would but you would have to change everything.
Old Jul 20, 2015 | 08:38 AM
Slugger088's Avatar
Monte of the Month -- August 2013
If I was in your shoes I would just sell the one I have and look for an SS. Much simpler.
Old Jul 20, 2015 | 12:41 PM
monte07's Avatar
best bet is to have a donor car to take every thing from it to put it in yours.
I have been looking into it my self I ran the parts I need.
engine trans ecu tcm bcu and and the wire harness to go with it to run the system and the other o2 sensors and a stronger fuel pump as well.
plus the engine cradle as well if the 5.3 engine wont line up with the 3.5/3.9 engine mount location. I am not sure if they do or not that part is hanging me up.
but I still like the 3.5/3.9 pepy of the engine.
if I did some thing like that I have to make sure to have a reliable dd before digging into a prodject like that plus all the odd and ends that run into a swap like that.
I am not saying don't do it expect it to be laid up for a while and time consuming of the swap.
it would be one of a kind to you if you did some thing like that it is possible to do but time and all the wiring
Old Jul 20, 2015 | 09:19 PM
Agreed, the time/cost of the swap just doesn't justify the work when you can buy a factory ls4 car with the same body style. Your options are even better if you don't mind branching out into a gp or impala to get the ls4.
I totally get engine swaps on cars where the engine wasn't available originally, but the huge depreciation on gm cars makes it hard to resist just buying a whole functioning car.
Old Jul 22, 2015 | 07:51 AM
Red Monte Carlo's Avatar
As soon as I catch an ls4 in the junkyard I'm doing the swap
Boost
Sep 3, 2019 05:08 AM
Knightwolf702
May 14, 2014 07:13 PM
z34phoenix
Jan 4, 2012 04:05 PM
matrx10503
Oct 26, 2010 09:59 AM
RickCoMatic
Jan 5, 2008 06:30 PM
