6th Gen ('00-'05): neutral safety switch location
Old Apr 15, 2024 | 11:29 AM
avendo's Avatar
Default neutral safety switch location
I have an 04 and i dont see my the switch under the master,my car would not start..move shifter around and it started..
Old Apr 15, 2024 | 03:50 PM
Take a look where the cable attaches to the transmisison. If there's a black plastic chunk there with a harness connection, that's what outputs what gear its in.
If there is no electronic module there, then it has the IMS which is internal to the transmission. I know the IMS setup was introduced in ~99 on the 4t65, but they were hit and miss with rollout. Worked on a 03 GP once that still had the external module, so I'm not sure what the 04 monte got.
Old Apr 15, 2024 | 05:00 PM
avendo's Avatar
mine dont have anything under there,i see the shaft and the tranny arm.i could not start my car,called AAA and when the guy got there,he did the same thing i did..put it in neutral and it started up..what would have caused it to not start..
Old Apr 15, 2024 | 05:26 PM
So it'll have the internal IMS then. Doesn't necessarily mean the transmission needs to come apart if it broke though - people have done the conversion to external for swaps and such.
Not sure if the IMS is actually causing the issue though- you'd have to get the wiring diagram and check the appropriate wire outputs from the transmission plug.
Old Apr 16, 2024 | 08:34 AM
avendo's Avatar
I saw on a site 2004 didnt have that internal IMS ..hmm
Old Apr 16, 2024 | 09:48 AM
AFAIK there's only two options on the 4t65, external (on top of the transmission) or internal (inside the transmission). If you think its somewhere else, you'll have to take a look at the wiring diagram for your car to see where it shows it being located.
Old May 23, 2024 | 11:28 AM
Rods02pacecar's Avatar
Both of my 02 Monte Carlos are internal. My switch is bad in one of them. My tranny harness plug is green. What I have found on Pontiac is their plug color is red and wires are different colors. What I need is the wires on my green plug to tap into to convert to a external neutral safety switch. Does any one have that diagram?
Old Aug 15, 2024 | 05:23 AM
Mike12gcc's Avatar
Default 4t65e nss
Ok guys I have a question here... My neutral safety switch is definitely internal and Im already in process of replacing it. The thing is how do I get the switch out? I mean I'm sure GM doesn't expect you to start breaking down
the transmission just to remove an internal nss, that's just ridiculous. The transmission casting is already off and I'm right where I can see and touch the switch. there's no room to bring it all the way down to get it out. Or am I missing something here.
Old Nov 29, 2024 | 08:26 AM
Mike Palatka's Avatar
What year is your Monte? I have the same issue on my 2003 3.8. I’m just about to give up and take it to a transmission shop. I would rather not take the car to a mechanic if I can get this done myself.
WolvenScout
May 24, 2024 06:40 AM
Jeffs02rwdSS
Feb 26, 2019 04:58 AM
craigh4575
Feb 3, 2010 07:04 PM
Wilco
Oct 27, 2009 06:50 PM
jerkstore83
Nov 17, 2008 10:03 AM
