need help figuring out wich 3800 I have
Old Sep 14, 2011 | 08:05 PM
PacerSS's Avatar
Most likely yes. Unless they just replaced the oil pan with a new version which I highly doubt because it would require new motor mount brackets. If you could take a pic of the top of your engine I'd be able to tell you. Oh and without the cover.
Old Sep 14, 2011 | 08:50 PM
bbengineer's Avatar
Just an FYI, all 2004+ (except possibly some built very early) Impalas and Montes got the Series III bottom end and heads (including the powered rods which was the major difference). The Series II top end (plastic UIM for NA, Gen3 M90 for SC) was mated with the Series III bottom end/heads and the Series II oil pan
No Impala or Monte every received the Series III top end from the factory
So even with a Series II oil pan and Series II top end, you won't be able to tell if you have the Series III bottom end without opening the motor up (or possible checking the serial number on the block)
BBEngineer
Last edited by bbengineer; Sep 14, 2011 at 11:15 PM. Reason: Fix Series II UIM error
Old Sep 14, 2011 | 08:55 PM
mwjames's Avatar
Pretty sure its got the black plastic intake, hopefully he didn't lie about it being a 05 with 75k on it, either way it runs good I guess.
Old Sep 14, 2011 | 11:05 PM
PacerSS's Avatar
Originally Posted by bbengineer
Just an FYI, all 2004+ (except possibly some built very early) Impalas and Montes got the Series III bottom end and heads (including the powered rods which was the major difference). The Series II top end (aluminum UIM for NA, Gen3 M90 for SC) was mated with the Series III bottom end/heads and the Series II oil pan
BBEngineer
The UIM for NA is plastic in the Series II
Old Sep 14, 2011 | 11:15 PM
bbengineer's Avatar
Yup, that was a typo on my part, I'll fix my post
BBEngineer
Old Sep 15, 2011 | 06:48 PM
nickhead's Avatar
if the oil pan bolt pattern matches which it shud. just the alum oil pan may signify nothing. call the dealer.
Old Sep 15, 2011 | 07:34 PM
Enzo354's Avatar
STILL SLOW
Take a picture of it and post it. Easy.
Old Sep 15, 2011 | 07:38 PM
bbengineer's Avatar
What is calling the dealer going to accomplish? They won't have a clue
If it has the plastic UIM, what good is a picture going to do without opening the engine up?
And even more importantly, what's the difference? There is no horsepower increase from the Series 2 to Series 3 NA motor and the only real internal difference is the rods, which don't break in the NA motor anyway...
BBEngineer
Old Sep 15, 2011 | 09:20 PM
I've heard the Bonneville guys mention what BBE mentioned about the series III bottom end. To be honest, neat to know, but unless you NEED to know for a performance modding reason, I certainly would not loose sleep over it.
Old Sep 18, 2011 | 08:20 PM
I'll be checking it this friday so until then my fingers are crossed hoping its series 3
Exactly what I was thinking- it doesn't matter if its a series 2 or 3 really, they're virtually the same engine- its not like you're comparing a series 1 to 2. The strength of the two engines is the same, and virtually all the mods are identical S2 to S3.
RattPack
16
Dec 30, 2015 04:09 PM
Denarius23
Sep 17, 2014 02:18 AM
golfstud2k4
Sep 29, 2010 03:37 PM
98BlackZ34
May 16, 2010 10:31 PM
sickofsoyo
Jan 5, 2009 05:43 PM
