Naturally Aspirated L36
Old Jul 18, 2009 | 08:03 PM
hbcase2's Avatar
Default Naturally Aspirated L36
Hey guys, just wanna get your opinions on how to get a NA L36 to run low 15s to high (maybe mid??) 14s in the quarter mile. Am not considering forced induction as of the moment due to budgetary constraints. I was thinking of these mods in order...
- K&N SRI
- Plog
- 2.5 DP
- ER Ratio Rockers or GT1 Cam
- Dyno tune (There's a shop here that does it for $150/hr)
I might possibly get the HV3 insert and ZZP's St1 Throttle Body, afterwards...
Old Jul 19, 2009 | 03:46 AM
hbcase2's Avatar
Another question... why does Motor Trend state that the 2000 SS goes 0-60 in 7.3 seconds and clears the quarter mile in 15.5 at 89.3mph (Link) to Car and Driver's 2002 SS that went in 8.6s/16.6s @84mph (Link). Aren't those closer to supercharged numbers?
Old Jul 19, 2009 | 09:20 AM
mrl390's Avatar
Dont pay any attention to the car and driver numbers. I dont know what they were smoking when they got them. The numbers should be closer to 7.5-8sec 0-60 and 15.8-16sec in the 1/4.
Old Jul 19, 2009 | 11:10 AM
IMO, with all the money you're planning on spending with a tune, cam, hv3, etc etc etc- you've got way more than enough for a top swap. Just buy it a piece at a time. I mean you've easily got $1k+ in mods listed there.
I had a buddy that had rockers, PEMS, 2.5" dp, straight piped exhaust, FWI, ZZP tune, 180 tstat, and a couple other minor things, and his best was like a 15.4 with all the stuff in the trunk taken out, as well as the passenger seat.
Personally, I don't like doing a cam in an L36 unless you're doing a TC too- we had a guy on the monte boards that got screwed with that (Buck)- and I saw a local guy go through that too. They're a lot more sensitive to where the power band is than an L67.
Old Jul 19, 2009 | 01:07 PM
hbcase2's Avatar
mrl390, I was wondering why the numbers seemed so... slow too lol!!
bumpin96, great point on the total cost of the mods... I'm now also trying to check out ZZPs SS M90 kit and if it's worth it if I get the M90 and L67 intake manifold myself and just get them to port it.
As I see it, the M90 is a bit simpler but it costs more. A straight top swap is just a little more work.
Old Jul 20, 2009 | 02:20 PM
ZZP's SS kit is for those that cannot do the labor of roughly the equivalent to a head gasket change. You end up buying a bunch of expensive parts that you'd never need with a normal L67 top swap. You're just paying extra for the conveinece of an easier install.
Old Jul 20, 2009 | 11:53 PM
hbcase2's Avatar
Thanks for the info, bumpin. Quick question though... what was the problem with the cams. I saw on a list that Buck (If it's the same person) was able to push 199whp on a NA setup? Something went wrong with the setup?
Old Jul 21, 2009 | 08:16 AM
From what I remember, he originally bought an Intense cam; and it moved the power band up too much, and he ended up not running anywhere near what it should- and they told him it had to have a high stall TC to work right (I don't think it was all that crazy of a cam either).
2003supersport
14
Apr 7, 2009 07:57 AM
sprfrk2005
Aug 8, 2008 04:24 PM
