A mysterious fuel smell
Old May 2, 2008 | 01:18 PM
shaboom5's Avatar
Default A mysterious fuel smell
Hey,
I have a 05 monte carlo ls with the 3400 engine. recently i've noticed a fuel smell most of the time when i'm getting off the highway and am on a decline. i didn't think much of it until a cople of days ago. i tried to see or smell where it was coming from and couldn't. Has anyone had this same problem of have any idea what it might be. (nocheck engine light or anything.)
Old May 2, 2008 | 01:26 PM
The Black Machine 29's Avatar
Default RE: A mysterious fuel smell
did you screw down a subwoofer box or anything in your trunk? the gas tank is extremely close the the sheet metal
Old May 2, 2008 | 02:56 PM
z34phoenix's Avatar
is it of rich exhaust or raw fuel?
i would check your fuel rail connectors to make sure the oring seals havent leaked... this is a common issue on the l67's not so much on your motor though.
next i would check the evap system... it purges fuel tank vapor to the intake to be burned... one of these lines could have cracked.. they start at a charchol canister at the rear of the car and move forward. hope this helps
Old May 2, 2008 | 07:55 PM
rysZ34's Avatar
check the fuel rail and see if you are getting any smell or if you can see anything. )
Old May 2, 2008 | 09:42 PM
shaboom5's Avatar
thanks i'll check that in teh morning.
anyone knw hoard that that would be to fix or how much it would cost?
Old May 2, 2008 | 11:24 PM
RickCoMatic's Avatar
I'd run it and look for a leak. Like, around the Fuel Filter where it plugs into that clip-in fitting with the O-ring. You are supposed to replace the O-ring when you do the Filter; but I know that a lot of times that O-ring is just left in there to leak!
Old May 3, 2008 | 08:47 AM
shaboom5's Avatar
I still haven't smelled it ina couple of days. i'm going wait for the smell.. then I'll immediately pull over and find out where its coming from. but right now an't pinpoint it . i'll check back later.
Dottie
Sep 22, 2014 09:41 AM
matrx10503
Dec 30, 2010 07:04 PM
my00monte
Dec 21, 2010 10:31 PM
WildWestSS
Dec 2, 2010 11:39 PM
Jun 24, 2010 02:37 PM
