How would I know if my transmission is slipping? I've been having issues with acceleration lately. I feel like I really have to give it gas to gain speed at an acceptable rate and if I floor it, the car will speed up quickly up to about 4k RPMS then goes to shift and I hear a ticking noise. I immediately let off the gas and it shifts fine.
If it was slipping you would feel exactly that, you would feel it slipping into each gear as it ships and it would kind of pull each time (hard to explain in words).
My guess is that you have a clogged cat, or it's getting clogged. What I would do is run it a little hard for a while and then crawl under it and see if the cat is glowing red, if it is then you have a bad cat. A shop can also do a pressure test for you. |
Originally Posted by trewyn15
(Post 456663)
Not going over 4k sounds like a cat to me too.
And your ticking could be because your exhaust is not flowing out properly. Test the cat first, and then see if anything else is still wrong and go from there. cat is the main problem first. |
Ticking, exhaust leak?
I had mine rebuilt a cpl months ago...cost me $1000.00....but worth every penny....
3 yr 36000 mile warranty... plus 3 free oil and filter changes..(once a year) |
A clogged cat won't be accompanied by any OBDII codes? I don't have any codes showing up. I will try and get it pressure tested this weekend.
Originally Posted by asmart82
(Post 457036)
Replaced my cat/DP with a ZZP one. Fixed my issues. Glad it wasn't the transmission!! The power it has now it amazing!
(Post 462001)
