mpg help
Old Nov 12, 2013 | 11:10 PM
Jakob Regal's Avatar
Default mpg help
Hey,
I just joined and just bought a 2000 ss. Since I bought it ive been having serious mpg issues. Most generally city and highway driving ive been getting anywhere from 15 to 19 mpg solid highway the best was 24. Im a very lightfooted person. I changed to synthetic oil and put a new air filter. Rpms stay between 1500 to 2000 normally excluding taking off. Ive had grand prixs before with 3800, but usually got 25 to 34 mpg. This just seems shocking.....any suggestions would be greatly appreciated.
thank you.
Old Nov 13, 2013 | 12:44 AM
Hi Jakob & Welcome to the MCF
How many miles on your Monte Carlo ?
When was the last time it had a tune up ?
Did you change the fuel filter ? Clean your MAF ?
Post as much information you can about how your Monte Carlo has been maintained. How does your Monte Carlo Perform ?
Look forward to your reply & hopefully one of our expert techs can assist you with your low MPG's > Good Luck & EnJoy the MCF !
Old Nov 16, 2013 | 01:25 PM
hctr154's Avatar
Is your SS the supercharged one? If so, that might be normal.
Old Nov 16, 2013 | 01:35 PM
Welcome to the Forum!
I believe a bit more info about your Monte will definitely help to Diagnose what may possibly be normal or what you need to do to improve it.
How many miles on it?
When was the last filter, oil change done?
When was the last time you put wires and plugs in it?
What kind of condition is the exhaust in? (cat)
What condition is the cooling system in (any leaks/Overheating)
Is the Check Engine Light On?
What codes if any if the light is on?
The more info you can give the better!
Thanks for joining the MCF Family!
Old Nov 16, 2013 | 10:53 PM
owens91's Avatar
I believe I had made a thread about this a while ago. I'm getting about 15 mpg city I rarely drive on the highway I did a full tune which included sparkpkugs and wires, fuel filter, o2 sensor recently changed fuel pressure regulator and upper and lower intake manifold gaskets. Still getying the same. I feel a bit of a transmisson problem/slip so that also could be a factor. I'm also thinking about changing the egr valve and gasket which sjould improve it hopethis helps
ChevygalSS
Mar 3, 2015 01:55 PM
montejass
Aug 22, 2006 06:39 PM
BeachBumMike
Jul 24, 2006 02:57 PM
SoDak98Monte
18
May 17, 2006 10:40 PM
montejass
Apr 5, 2005 11:58 PM
