Minivan Problem (Dodge) - 3800
Old Nov 23, 2011 | 06:55 PM
Default Minivan Problem (Dodge) - 3800
As of yesterday the minivan has been having some issues running. It threw p1297 which says that the voltage to the map sensor doesn't change from when the van is off to when it starts.
We replaced the map sensor already, seemed to run a little better, started it again, runs like crap again.
It is bouncing a little when it idles, and the engine is shaking the whole van horribly. You can hear the exhaust, it sounds like there's paper in there or something, possibly missing bad or bad timing?
Does anyone know what this could be? I'm starting to think a spark plug problem, maybe something to do wit the spark or a bad injector?
I can upload a video if needed.
Old Nov 23, 2011 | 07:00 PM
BlackRainSS's Avatar
Thats weird hope someone can help I'm no good with vans I really hate them
Old Nov 24, 2011 | 08:17 PM
mwjames's Avatar
Check the intake for leaks and replacing cracked hoses is were I'd start. check the wires running to it also
Old Nov 25, 2011 | 02:59 AM
everything checks out to be good, not leaking at all, all pcm wires are secure, no visual damage to any wires or plugs
Old Nov 25, 2011 | 04:14 PM
03SSLE's Avatar
Since you got a P1297 code I would start by checking the circuit that provides voltage to the MAP sensor.
RattPack
16
Dec 30, 2015 04:09 PM
Denarius23
Sep 17, 2014 02:18 AM
golfstud2k4
Sep 29, 2010 03:37 PM
Farfig
May 22, 2008 07:02 PM
Farfig
Dec 22, 2007 03:13 PM
