MAF with a turbo
Old Sep 27, 2008 | 05:23 PM
f16fixr's Avatar
Default MAF with a turbo
Since I will be modding my car with a turbo, i am going to do a water/meth injection with it. Does anyone know if the MAF sensor is reprogrammable on the 03 monte ss's so i can set when mypump kicks on at a certain amount of boost from the turbo?
Old Sep 28, 2008 | 10:55 AM
2000_BLACK_SS's Avatar
Default RE: MAF with a turbo
i am no expert but i dont think that your stock MAF is going to be able to flow enough with the turbo.
Old Sep 29, 2008 | 08:19 AM
If you're looking for a boost signal, you don't want MAF- all it gives you is a frequency from 0-11,000 Hz that tells the amount of airflow coming in. What you want is MAP- which gives the pressure in the manifold in voltage.
dgm
Sep 8, 2014 07:03 AM
vikesfan
Jan 29, 2014 12:23 PM
04SuperchargeR
Jun 11, 2013 06:39 PM
taz7nads
Jul 19, 2012 12:28 PM
bama_z34
Nov 29, 2010 10:00 PM
