M62 Supercharger
Old Oct 27, 2012 | 11:05 AM
rosemarycars's Avatar
Originally Posted by mrl390
You wont be able to use it if you dont have a mount or the drive for it. Those grand ams had a special supercharger housing that was formed specifically for those cars so it could mount in front of the engine (to the side technically) instead of on top. Instead of being open on the bottom, the housing necked down so it could mate with the throttle body opening on the stock intake manifold. Also, it had a TB build in to it that snaked down so it sat down below the actual body of the supercharger, so when you turned the supercharger on its side like they mount on the grand ams, the TB was actually close to its original location in the engine bay. Also, the snout had a long bearing shaft bolted on with a pully on the other end so the accessory drive could turn the supercharger and the supercharger could still sit on the opposite side of the engine. Its a pretty complicated unit. You cant just use ANY M62 you need the one specifically made for those grand ams.
Hi,
I have a 2004 Monte Carlo SS Super charged Engine. Would like to increase the HP, to around 330HP. Do you know what kind of Chip I need to buy? I am new to the Hobby, the car has Headers and would need under Pullys, to support the HP.
Thanks,
Nick in N.J. 07981
973-599-1842
Old Oct 27, 2012 | 03:34 PM
Originally Posted by rosemarycars
Hi,
Thanks,
Nick in N.J. 07981
You don't need a chip.. you need a tune... You may want to remove your phone number also so you don't run into spam issues.
All you need to do is read this thread and you should be set with all the information you need
https://montecarloforum.com/forum/ni...-bumpin-24895/
Old Oct 28, 2012 | 09:47 AM
Thanks so much for the info? a Tune is regarding buying cold air intake, and the other parts that go with the increased HP.
Old Oct 29, 2012 | 04:27 PM
I don't understand your statement/question. A tune doesn't need to go with anything else, it changes the fuel tables and timing and such things dependent on the tuner.
CAI's don't need a tune as the PCM can adjust for them, tunes will just get you that extra bit that the car didn't get from the factory tune
Old Oct 30, 2012 | 10:31 AM
MonteLSV6's Avatar
Heres what I got for some easy power gains; CAI that I heat treated, summit racing dp with high flow cat, reso and u bend del, and milzy modified heater tube. 180t thermo is going in start of summer followed by a pcm. Its quite peppy now
my00monte
Sep 10, 2011 08:16 PM
recci03
40
Jun 17, 2010 09:26 PM
Recluse tha Ripper
Jun 17, 2009 01:12 PM
96MonteCarloSS
Nov 15, 2005 08:25 PM
mcarloss04
Sep 25, 2005 01:09 AM
