Luke warm heat only 2005 MC SS
Old Jan 10, 2011 | 01:12 PM
Uncle Mo's Avatar
Default Luke warm heat only 2005 MC SS
I have a problem with the heat in my 2005 Monte Carlo SS where the heat no longer gets very hot. It’s pretty much now on the cool side (Luke warm)
Also I have now taken notice of the temp gauge remaining on the colder side.
As for the heat, it began last year and seems to me back then I could hear a vacuum noise of some kind when I changed the vent settings from defrost to floor setting, almost as though it was sticking and then became stable, which produced hotter air.
But now I don’t hear it anymore and it just blows luke warm air only.
If it’s a vent problem where the doors are not operating properly do I need to get under the dash to address the problem?
I am thinking about changing the thermostat anyway and replacing it with a 195 degree, does this sound alright?
But I need to get the heater working for my wife.
Thanks in advance for your time.
Uncle Mo
Old Jan 10, 2011 | 01:57 PM
My first thought is that your T-stat is hanging open. I would replace that first and see if it solves the problem.
Old Jan 10, 2011 | 02:04 PM
monte07's Avatar
i would replace the t-stat and make sure all the air is out of the system after replacing the t-stat
Old Jan 10, 2011 | 02:08 PM
Enzo354's Avatar
STILL SLOW
Yea thats the Tstat. Mines only luke warm. Guess having a 160* drilled tstat in the winter isnt the best idea.
Old Jan 11, 2011 | 11:10 AM
jbrd's Avatar
Talking
I had the same problem with luke warm heat. I replaced the T-stat and the hot air worked just fine again.
Old Jan 11, 2011 | 12:21 PM
biggriggs's Avatar
I popped a drilled 180* into mine two years ago in January.
When the ambient temp dropped down to about 20* or less at night, the car wouldn't get above 140* even after a half hour of driving. Watching the temps drop down even further when the heater was on, and having cool air blowing from the vents got old fast.
Switched to a non-drilled 180* as soon as it was warm enough to change the t-stat without my hands going numb.
OP: Any luck with the issue?
Newer thermostats are made to stick open when they fail, so that the car won't overheat in the event of a thermostat failure. This isn't always the case when the heater is blowing cold air, but is a cheap fix if so.
Seppeku
Oct 8, 2017 08:35 PM
Raider
Jun 18, 2014 11:15 PM
Emnasty600
Jul 2, 2011 09:38 AM
ssir terrence
Oct 3, 2008 03:02 PM
skimmy
Jan 13, 2007 02:14 AM
