7th Gen ('06-'07): LS4 Question
Old Jan 8, 2018 | 11:59 AM
96z34man's Avatar
Default LS4 Question
In a (so far unsuccessful) attempt to replace the plug on cylinder 1, I had to unplug the sensor, or whatever it is, next to the plug wire.
What is this thing?
Old Jan 8, 2018 | 01:07 PM
Are you referencing the coil packs?
Or a different sensor near the engine?
Old Jan 8, 2018 | 11:10 PM
96z34man's Avatar
A different sensor ON the engine.
Old Jan 9, 2018 | 10:54 AM
If it's the sensor right near the front exhaust manifold and plug #1 it should be the engine coolant temp sensor
If this also isn't correct, can you provide a picture of the sensor in question. Thanks!
