LS4 Question
In a (so far unsuccessful) attempt to replace the plug on cylinder 1, I had to unplug the sensor, or whatever it is, next to the plug wire.
What is this thing? |
Are you referencing the coil packs?
Or a different sensor near the engine? |
A different sensor ON the engine.
If it's the sensor right near the front exhaust manifold and plug #1 it should be the engine coolant temp sensor
If this also isn't correct, can you provide a picture of the sensor in question. Thanks! |
