Low engine oil light
Have been having issues with my low engine oil light/add engine oil light coming on before my last few services (Roughly anywhere from 200-400 or so miles before car is due for service, which I do every 3000 miles).
The dealership has checked it the last few times before service and said that it isn't registering low on the dipstick, and more recently they have told me that it may possibly be a problem with the oil pump, but would have to do an analysis to know if this is infact the problem.
Before I shell out 100 bucks for the analysis which may be pointless, has anyone else had this problem, or if not does the oil pump issue sound like a logical cause?
Any input would be great, thanks!
Wow, having this problem on an '06 is pretty alarming. I can't say for sure on your car but previous cars I have had only had the engine oil low light come when the oil is so low it only registers a couple of p.s.i. I believe it is sensing the actual oil pressure and there is not like a float or anything in the pan measuring the level. I would say that if the light comes on and then goes out, the oil pump could be the suspect. Again, maybe someone with some more experience with Montes will chime in.
I'm not an expert in oil pumps, BUT, does your car have an oil pressure guage? If so, when you rev the car, does the pressure increase and when you let off of it does it decrease? If so, I'm not sure I would suspect a oil pump.
In all GMs I have worked with, the low oil light usually means you are 1.5-2 quarts low on oil. If the dipstick is showing you have sufficient oil, perhaps the oil level switch (in my experience located in the oil pan) is failing??
i don't wanna scare ya, but that's exactly what mine was doing when i realized it was using oil with the DOD. About the only thing i can think of is that when you check the dipstick the oil hasn't settled from when it was running and it's still hitting the dipstick after you wipe it off to make you think there's still oil at that level. Good luck
I have personally checked it, and always check once, wipe off, check again, and the dealer has also checked it because they want to be the ones to document, or add and document if it is low, but it has been fine.
I have wondered as well if possibly the sensor is failing, but again to me that doesn't seem entirely logical either due to the timing of the issue.
I got really REALLY lucky and called gm to see when my powertrain warranty was up and it ended up being like 2 days away so i got it in ASAP. they ended up changing the oil pan gasket and cleaning the engine up really well. The oil pan gasket has some sort of shield to stop the oil from getting into the pistons and burning upon ignition. there are a bunch of threads on here about the problem, but that's what happened with the "angel"
idk what to tell ya other than my DIC would read low oil level anywhere from 2,800 to 2,500 on a 3,000 mile oil change. After the first time i figured i must have forgot to put the last qt. of oil in (since i always get the 5 quart bottle at walmart and our car takes 6) but the second time i remembered reading something on here about it and called gm as soon as i could since it's a known problem.
hotrodharley
Nov 15, 2013 11:37 AM
TMoney
Aug 18, 2013 02:37 PM
dogmanx
Nov 17, 2011 11:37 AM
