Looks like Lucy has the flu
Old Nov 13, 2009 | 09:16 PM
PINKFLOYD_'s Avatar
Default Looks like Lucy has the flu
My temperature would "stick" sometimes. Say I park the car for 10 hours, it will start at 200F. It would only do it once a while and it wouldn't get hotter. Now it's getting worse and now reaches past* 260F. I worked on it tonight by changing the thermostat, letting the air out, and buying a new sensor. Still the same results. There is no steam,nor water bubling. Infact the Antifreeze isn't even hot enough to make tea to the Touch*. My sense is telling me it's a broken instrument? It's a 2004 SS.
Any thoughts?
Thank-you
Old Nov 13, 2009 | 10:57 PM
this forum is so messed up right now, just wait and see, hopefully it will be up and running smooth soon!!
Old Nov 14, 2009 | 12:08 AM
Wilco's Avatar
Any thoughts?
Thank-you
Did you check the system's pressure? If the radiator's cap is bad it could lead to overheating/erroneous reading! Also, you may want to check the integrity of the heads/manifold gaskets for air leaks! If you're getting air in the system but no leakage anywhere, a gasket maybe allowing air in and causing the system to overheat.
Old Nov 16, 2009 | 10:05 AM
It's possible that it's just a faulty gauge, it's a common problem on our 6th gens.
If nothing is mechanically wrong, it could be your gauge cluster.
RocknSS04
May 21, 2009 11:47 PM
PINKFLOYD_
May 20, 2009 08:35 AM
ChevySSGirl
May 5, 2009 04:27 PM
BeachBumMike
Feb 25, 2008 06:07 PM
TrapShooter8
Jul 11, 2007 06:26 PM
