Look what I got in the mail.
#61
I have a couple of pictures in the garage. But here is a few more. I've been changing the color on the front to see what I like best. Once I painted the flat grey and it didn't come out great so I've been testing different colors on the front to see what I like the best then I'm going to take it to a body shop and let them paint it
Full grey
Grey with black spoiler
Here's the engine with a blue I picked out
Current color of the front, black metallic
#65
Went to the track on Sat. didn't do to well with the tune I had. Kept bogging on launch and wouldn't shift due to misfires in the higher RPM's. Its back on the stock injectors and some more tuning.
there's a lot that goes into but those are the main things
#66
1K is just getting the turbo in and the engine to run with it in there on only 5PSI. I want to get to 15PSI which will require upgraded fuel pump ($70-$90), injectors ($350-$400), engine upgrades ($Arm), bigger turbo ($800-$1k), racing trans ($2K-$3K). I'll more then likely have to replace the trans at the 5 psi level once I get the tune dialed in.
#68
If you do have a 2000 MC SS like your names says then we don't have the same engine. ZZP and some others make a complete turbo kit for the 3800. You should look into them.
#69
I have it tuned for part throttle, I need to up the boost lol.
Here is a vid from my last test run. If you listen you can hear the turbo spool before the engine noise drowns it out.
VIDEO0008.mp4 - YouTube
#70
bearbear, gonna check that video out!
