Look what I got in the mail.
Old Oct 26, 2011 | 07:28 PM
  #31
zipper's Avatar
Do you have a turbo blanket? It might help with such an experimental build. I can't wait to see this done.
Old Oct 26, 2011 | 07:40 PM
  #32
bearbear3_4's Avatar
I do have plans to add a blanket and wrapping all exhaust pipes.
Old Oct 31, 2011 | 03:46 PM
  #33
Removed the oil pan and I have marked a few locations for the oil return.
Old Nov 4, 2011 | 04:23 PM
  #34
Just an update, still waiting on some parts to finish the oil pan but I tapped for the oil feed line. I just went right off the oil filter pedestal. Could of just tee'd off the pressure sender but it had to come off to get the pan off and the line kit came with a fitting I could use.
Old Nov 4, 2011 | 05:22 PM
  #35
can't wait to see more!
Old Nov 5, 2011 | 06:06 PM
  #36
Well after getting everything installed come to find out the ac compressor hits the feed and drain so it's back to the drawing board.
Old Nov 25, 2011 | 04:25 PM
  #37
I was able to make the drain and feed work where they were at. Also finished the downpipe and wastegate mounting and is all installed. Just waiting on the intercooler, heat exchanger, and fittings and the hard part is over. Just will have little odds and ends to finish.
Old Nov 27, 2011 | 02:16 AM
  #38
Enzo354's Avatar
STILL SLOW
That looks great, I hate you
Old Dec 12, 2011 | 06:36 PM
  #39
Almost ready for the first startup with everything connected. Just need an 02 sensor that I broke and a heat exchanger with fitting to finish up.
Old Dec 12, 2011 | 07:20 PM
  #40
zipper's Avatar
Please tell me that you are going to go straight to a dyno when all is said and done. That is looking really good and clean so far.
