Look what I got in the mail.
Old Aug 3, 2012 | 11:59 PM
  #101
bearbear3_4's Avatar
Finally have it tuned. The old turbo blew its seals so I upgraded to a T70 with a .84ar exhaust which is to big for this engine. Once I get some funds I'll be going to a different a/r. Here is my best run on street tires.
I'm 180H
As you can see when it spools it's quick but a slug till then.
Old Aug 4, 2012 | 09:15 AM
  #102
zipper's Avatar
That's awesome that you went to the track with that thing. You can tell you were running street tires, lol. If you got those 60' times down to a 1.90, you would be very close to running a 12 second 1/4.
Old Aug 5, 2012 | 10:39 AM
  #103
Next weekend I'll be making some more runs on DR's. I haven't decided if I will up the boost to 10psi but I am going to get some liquid c02 for rapid cool downs to try and get my intake temps to about 100 from 140.
Old Aug 8, 2012 | 11:53 AM
  #104
Here is a picture of the new setup with the bigger turbo.
Old Aug 8, 2012 | 12:30 PM
  #105
That's a pretty clean, custom setup!
Old Aug 22, 2012 | 12:30 AM
  #106
Ended up busting the input shaft on the trans yesterday. Waiting on a replacement.
Old Oct 13, 2012 | 06:46 PM
  #107
Input shaft replaced with a ZZP hardened one. Ended up cracking the flywheel last weekend on my last run at 10 psi.
Be jealous
<iframe width="640" height="360" src="https://www.youtube.com/embed/6DfwjaFRKiQ" frameborder="0" allowfullscreen></iframe>
Old Oct 14, 2012 | 11:00 AM
  #108
monte07's Avatar
check the oil as well when you replace the flywheel. i dont want you to over look any thing. the reason why the last time i seen a cracked or shatered fly wheel the crank in my mustang said peace im done when i went to 12 psi on my supercharger with a stock bottom on the mustang i have. i wouls drain the oil to make sure nothing else is hurting or starving. i know you have a lot of love in your monte thats what i was saying check whats going on with it. all at once so it wont be a suprise there not just that i would like to see it on the track when i am in your area next year
Old Oct 15, 2012 | 12:23 PM
  #109
Good idea, I'll drop the oil pan and check the bottom end when the trans is out.
Old Oct 15, 2012 | 02:22 PM
  #110
Looking good! How hard is the input shaft to get to?
