Larger Throttle Body?
Old Jul 22, 2007 | 02:46 PM
Cowboy6622's Avatar
Default Larger Throttle Body?
Alright guys, your expertise so far has been great. I would like yet some more advice (yes, I'm quite annoying, I know). I would like to know if with me getting a CAI soon, and a catback system, if it would even be worth it with these little mods, nothing to the engine itself, to upgrade to a larger throttle body. I have a non-supercharged 3.8L. I am thinking of taking my car to a dynoshop after I do this and have the computer retuend for all of this and 93 octane, so what do you think? Shoudl I upgrade the throttle body?
Old Jul 22, 2007 | 03:18 PM
Cowboy6622's Avatar
Default RE: Larger Throttle Body?
Oh, and back to my thermostat question... if I were to have my computer retuned, should I go on with the thermostat to?
Old Jul 22, 2007 | 05:22 PM
AlGeeEater's Avatar
You would really only benefit from a larger throttle body once you install a new exhaust and when you're sucking in true cold air from outside of the car, not sucking in warm air from the engine. If you ARE going to go with a new CAI, i'd suggest going with a fender well intake.
I'd replace the t-stat to a 180 degree either way, they're cheap.
Old Jul 22, 2007 | 08:32 PM
z34phoenix's Avatar
yep deff go for the larger TB. its a very good mod.
also go look at ZZPerformance.com they sell something called a HV3 high velocity intake insert. it is like having a ported intake manifold. deff a good mod too
Old Jul 22, 2007 | 09:18 PM
Cowboy6622's Avatar
i forgot to mention... what size should i get? somehow i'm thinking the cadillac north star throttle body is a bit much. what should i get for a non-supercharged 3800? i'm thinking about following your advice and getting the intake insert from zzperformance along with his 68mm throttle body... would this be sufficient or should i try for something bigger. i want to get a cold air intake still, probably one to go along with a ram air hood and be done with my car. i'm really thinking hte 68mm... and i'm wondering if the stage 2 thing would be worth the extra $150. also, what good would a throttle body spacer do me, if any?
Old Jul 24, 2007 | 08:16 PM
Cowboy6622's Avatar
the high velocity intake thing shows it taking a bit away from teh low end performance.... what do you guys think i should do? is it worth it for hte top end? and also, is it worth it to tune for the 180 degree thermostat or just leave it be?
Old Jul 24, 2007 | 09:16 PM
z34phoenix's Avatar
Ok:
-TB spacer is a YES
-Velocity insert is a go. yeah you might loose a little low end power, but with the better TB and Spacer you will gain throtle responce that will make up for the loss of power....
-Stage 2 all the way! if you can afford it its deff the way to go.
Old Jul 24, 2007 | 09:19 PM
Cowboy6622's Avatar
thanks
Chaotic77
Jun 27, 2012 04:46 PM
DuSSt
Jan 18, 2012 11:41 AM
BeachBumMike
Aug 19, 2006 09:08 PM
01whitess
Apr 8, 2006 04:12 PM
montejass
Jun 3, 2005 11:53 PM
