L67 Swap Questions
Old Sep 8, 2011 | 11:15 AM
01MoneyCarloSS's Avatar
Default L67 Swap Questions
Ok, I have a 2001 Chevy Monte Carlo SS with the 3800 Series II V6. I blew a head gasket and I want a supercharged 3800 Series II V6. I found a Guy on Craigslist with a 2004 Chevy Monte Carlo SS Supercharged with 111,000 miles. He said I can have everything for $1000 which includes engine, trans, wiring harness, pcm, axles.... He said he is going to drop the entire A frame so everything that comes with that. He also said I could have the instrument cluster..
Now my question, Is it a good deal, and is there anything else I would have to buy separately in order for it to work?
Old Sep 8, 2011 | 11:22 AM
That does sound like a good deal, just make sure everything is good & that the mower isnt blown
Old Sep 8, 2011 | 11:38 AM
Blazed SS's Avatar
IT HERTZ
that does not sound like a bad deal to me also just make sure ithe motor turns .
Old Sep 9, 2011 | 12:18 AM
How can I check to make sure the mower is not blown. Or did you mean motor.. lol
Old Sep 9, 2011 | 03:54 PM
Enzo354's Avatar
STILL SLOW
Have him start it before he takes it apart for you.
Old Sep 9, 2011 | 04:59 PM
PacerSS's Avatar
If it doesn't turn that's no big deal really, the bottom ends on the engine are transferable.
Old Sep 10, 2011 | 01:07 AM
Ok, now is there anything else I need to buy other than fluids to get it running?
Old Sep 10, 2011 | 02:08 AM
Enzo354's Avatar
STILL SLOW
Nope, it might be easier to slip on some headers while you have the whole frame out, you wont regret it.
Old Sep 10, 2011 | 08:19 AM
If you have the engine out, you want to tear it down and redo all the gaskets.
Old Sep 10, 2011 | 09:32 PM
Not too bad of a deal really. You could probably do better, especially on mileage- but not a ton, and may not be worth the wait. The upside is you'll know for sure you have all the parts you need to make it work, so you won't be having to hunt for anything.
