L36 - l67
L36 - l67
Hey guys im lookin to swap over on a budget, and i had a few questions
What is the difference between the L36 and L67 heads? and can i get head work done to make it work?
Are you guys happy with the swap?
I don't know exactly what you mean when you say "can i get head work done to make it work" but if you're talking about will L67 heads fit on your engine block, then the answer is yes. The main difference between L36 and L67 heads are that the fuel injectors are in the L67 heads, whereas the injectors our in our LIMs in the L36.
It would be great for you to do a top swap, that way you have a little higher compression which will help you make more power.
You should also weigh your options in terms of just swapping an entire engine/ tranny from an L67 loaner car. It might be cheaper if you look hard enough. Then you can get a new tranny, and engine (with lower milage than you have already we are assuming).
or u can do like i did and do and ssm90 swap with a custom lim from zzp and u dont have to screw with the heads saved alot of hassle imo i but the twin belt drive on from a gtp and i diddnt have to screw with anything major on my engine
on a budget
i only have about 500 bucks in my complet set up and the furl logs arnt required if you have any fabricating knowledge mine are cut with an fitting brazed on and braided stinledd line inbetween cost me 15 bucks and all u have to do is watch club gp there is alaway somone selling a kit hell im thinking about selling mine b4 to long and goin turbo
alright i feel like i have left out some info.
I own a 1998 Monte Carlo Z34
well at the moment my car sits on 160k and runs like a dream
and according to the swap section alot of the 98 z34 parts such as the tranny and all that stuff.
My end result is a nice show car, not over the top racing. Like the member (Bumpin96monte) that had the nicely polished superchager. I saw that and i wanted it.
Haha Bumpin it was u that had the blower i wanted lol
Now its sitting in a box in my bedroom- still not sure what I'm gonna do with the polished M90. My plan before I traded my old 99 gtp in was to stick it on there, but that idea is shot now. Still toying with the idea of top swapping my impala- but I think it might be kindof a waste with such an otherwise relatively boring looking car. Who knows....
