ignition switch issue
Old Jul 18, 2015 | 09:09 AM
avendo's Avatar
can you open the door to shut the key off? or do you have to reach through the window?
Old Jul 19, 2015 | 08:31 PM
avendo's Avatar
I bought a cylinder and got to make my key fit
Old Jul 21, 2015 | 04:59 PM
avendo's Avatar
200 bucks to get key coded..yikes
Old Jul 21, 2015 | 11:35 PM
Originally Posted by plumbob
>Jason, I believe the previous posts with the Passlock/ Passlock 3 and Passlock3+ instructions link would be for gen 5 Monte's that do have a chip in the key, would they not? I didn't see any model years listed in the instructions.
BTW the re-learn instructions you posted are greatly appreciated. Although I have Tech2, I'm sure many other members that don't appreciate the effort.
I know those instructions work for the '00-'05 Montes and '99-'05 Grand Ams (all GM cars with non-chipped keys, the chip is in the lock cylinder, not the key on these models). I honestly don't know what version of Passlock they are for. These instructions are commonly used when you swap in a re-programmed/donor PCM into a car, but I have used them in swapping a lock cylinder on a few cars.
Follow the PCM relearn. It's recommended to reach into the car via the window, to prevent any additional electrical drains or possible disruptions. Also set your ebrake before you start to stop the day time running lights.
Old Jul 22, 2015 | 07:21 AM
avendo's Avatar
Do i need to replace both parts?
Old Jul 22, 2015 | 11:40 AM
avendo's Avatar
do the daytime lights screw it up on sitting there,i got my car to start letting it sit with the key on for 15 min,but this morn nothing..
Old Jul 22, 2015 | 04:57 PM
avendo's Avatar
do I need the switch too?
Old Jul 23, 2015 | 09:58 PM
Unfortunately, I don't know enough about the starting problem you are having.
Is the security light on? Has the car been checked for codes? Does it crank? Do you know if you have fuel pressure?
Old Jul 24, 2015 | 05:12 PM
Scott_S's Avatar
Recoding a key yourself isn't hard at all. I just had to recode two cylinders last month (my mother's (impala) and my own(monte)).
Did you buy the cylinder rebuild kit, or just the cylinder itself ?
If just the cylinder, you;ll have to buy extra tumblers and maybe springs.
First you have to tear apart the original cylinder to find the tumbler combination. then you assemble the new cylinder with the new tumblers/springs according to the original code.
1Aauto has a video about it on youtube.
If you need more details about rebuilding the ignition cylinder or replacing the ignition switch, let me know.
Exactly what symptoms are you having ? I could probably help diagnose the problem from the symptoms. The impala only needed a cylinder, while mine needed both the cylinder and switch.
For future reference, our keys (00-05) DO NOT have chips in them. The ignition cylinder shroud is what has the chip (passlock) in it. I've had multiple torn completely down and have seen the passlock chip in the cylinder shroud.
My current aftermarket key from the locksmith doesn't have a plastic head (no where to put a "chip") and it works just fine.
Old Jul 24, 2015 | 05:59 PM
avendo's Avatar
I got complete kit w tumblers,gm package.
