I am sick: 1998 MC transmission issues
Old Oct 25, 2013 | 02:13 PM
Originally Posted by red04montels
I've seen plenty of high mileage L36, L67 and such have the crank sensor go out, more specifically
So I'm guessing a 3.1 is L36? (that's what his 98 has in it...)
Old Oct 25, 2013 | 07:43 PM
clovis's Avatar
Thank you for the replies!!!
My dad bought this car new in 1998, and I got it from him in 2003. It has always had regular oil changes. I have never hot rodded or abused this car in any way. I'm gentle on the car. I am the 'grandpa' you don't want to get behind at a stop light.
The only repairs that I've had to make on this car were the intake manifold gasket and an alternator.
I am surprised that I've lost coolant sometime recently. I check it on a regular basis, and checked it again when I pulled the tranny dip stick. The antifreeze was low, and it stinks to high heaven. It smells abnormal to me. I washed my hands 4 times and could still smell the stink of the antifreeze on my hand.
My mechanic says that the tranny cooler is not leaking into the radiator.
The tranny fluid is brown, but does NOT smell burnt.
Thank you again!!!! Please keep the posts coming!!!
Old Oct 25, 2013 | 07:45 PM
clovis's Avatar
I forgot to mention that the car is NOT overheating nor does it appear to have overheating tendencies.
Old Oct 25, 2013 | 07:50 PM
clovis's Avatar
I do have a question:
Somewhere on this forum was a post by a GM tech.
In that post, he said that there are two tubes running through the transmission. These tubes can be seen when the tranny pan and gasket is pulled.
In that post, he suggested tapping those tubes back in with a hammer, and then zip tying them.
I can't find the post now.
Does this apply to the tranny in my MC?
What do you zip tie the tubes to?
THANK YOU AGAIN FOR YOUR TIME AND HELP!!!!!!!!!!!! IT IS APPRECIATED!!!!!
(And yes, I still feel sick about losing my Monte).
Old Jan 26, 2014 | 08:23 PM
clovis's Avatar
Update:
I kept driving the car some, but not a ton, until I started having hard shifting one day in all gears.
I let the car sit for quite a while, not sure what to do with it. I was afraid that I would be dumping money into a car that was headed to the scrap yard.
I took it to my mechanic, and he was a bit stumped too.
We decided to replace the camshaft sensor at a cost of $35 plus labor. He was swamped with work, and I was in no hurry to hear "You've got a trashed tranny." I let the car sit for a good while so he could get to it.
I went to pick up the car today, and it shifts fine after replacing the cam shaft sensor.
Sure, I only have about 40 miles on it since then, and those miles are basically split into two different days of driving.
Time will tell, and I'll try to update after I get some decent miles on it.
Thank you so much!!!!!
Old Jan 28, 2014 | 07:53 AM
z34phoenix's Avatar
sometimes with the CEL and a major sensor failure the car will be in limp mode and command harder shifts. the 4t60e can not command higher shift pressure as it is vac controlled on that car but harder shifting does happen with limp mode.
Old Jan 30, 2014 | 03:09 PM
clovis's Avatar
Thanks, z34.
The CEL has been on forever, but the car never went into limp mode.
I wonder if the camshaft sensor was sending too many signals, or at least signals at the wrong time, causing it to shift prematurely.
Of course, I'm just guessing, but thankful to have my MC back and running again. It felt great to drive her!
YeahDoggie
Aug 3, 2013 01:55 PM
samuelkowal906
Aug 26, 2009 05:43 AM
Cos29
Jul 14, 2007 08:44 PM
04MonteLS
Jun 30, 2006 11:34 AM
04MonteLS
Aug 13, 2005 05:38 PM
