how too beef up the tranny???????????
Old Aug 15, 2010 | 12:32 AM
siouxcity04montess's Avatar
Default how too beef up the tranny???????????
ok well i dont know much about transmissions.. so i have a 04 ss/sc the only mods done to it is a u-bend delete and an fwi.. but it has about 80xxx on it and i wanted too kinda beef up the tranny b4 i proceeded and added more mods. u know too be safe.. so any things u guys could think of too help beef up the tranny and too make it last longer would be awesome) thanks
Old Aug 15, 2010 | 01:20 AM
yutzybrian's Avatar
Depends on how much you want to put into it. A heavy duty 4th shaft is definitely recommended in my book since that's the shaft I've seen fail the most in the 4t65e. If you want to go extreme you could get the complete upgrade kit but that'll run ya over 2K. I can't remember exactly what all comes in the kit, but it should be just about everything. Intense's site doesn't want to load the kit for me for some reason.
Link
Old Aug 15, 2010 | 02:11 AM
With your current mod level, you're fine. Keep driving until it breaks from normal usage.
Lots of people with basic 3.4" pulley setups running about 300 crank hp run the 4t65's daily for years and years (heck the 4t65's run behind the LS4's putting out 300 crank hp stock; granted with a few alterations).
I wouldn't start worrying about strength issues until at least mid-low 13's in the 1/4 (mostly because most of the hard parts that fail aren't just a simple afternoon bolt in).
You want to honestly make the tranny last longer? Keep up with regular maintenance, and drive the car easy. WOT runs, skipshifts, WOT downshifts, hard launching, etc all stress the parts.
Old Aug 15, 2010 | 01:41 PM
zipper's Avatar
If you still want to upgrade the tranny go here: http://www.tripleedgeperformance.com/
Talk to the guy there and let him know what your goals are and he should be able to set you up with a really good tranny.
slinkeey
Feb 3, 2009 10:33 AM
silver bullitt
Aug 29, 2008 02:01 PM
Cowboy6622
Aug 26, 2007 12:39 PM
04MonteLS
Apr 27, 2007 03:56 AM
