how do i change the spark plugs on a 2003 3800?
Old May 16, 2016 | 10:29 PM
user 35764368's Avatar
how far can you rock the engine forward without breaking something?
Old May 17, 2016 | 09:02 AM
plumbob's Avatar
Rotate the engine forward far enough for the second (unused hole) in the dog bone to line up with the one you pulled the bolt out of. Then insert the bolt you took out into that hole to hold the engine in place instead of using a strap. Also loosen the other bolts that pass through the rubber bushings so you don't tear the bushings when you pivot the dog bone.
The book also says to have the transmission in neutral when you rotate the engine forward, I suppose so there is no strain and/or resistance on/or from the transmission. Use ACDelco Irridium or NGK Platinum plugs. Definitely not Bosch.
Old Sep 14, 2016 | 01:25 PM
russehrgood's Avatar
Can you change the rear sparks plugs while the car is up on the lift? A mechanic says you reach them easily. If so, I'll change the rear plugs next oil change.
Old Sep 14, 2016 | 03:21 PM
monte07's Avatar
I noticed when helping my neighbor with his 3800 monte it was next to a pita to go from the bottom. but doing it from the top to me is a little easier than bottom. but with some negotiating skills but not that pita as some think. once you do it the first time you end up making notes on the best way to get to the plugs for each one in the back
Old Sep 15, 2016 | 10:14 PM
No reason to bother with all that mess. If you don't think there is enough room, undo the dogbones and rock the engine forward. It's 2 simple bolts, doubles your space, and puts them at an easier angle.
Old Sep 17, 2016 | 05:15 PM
I've always done the plugs from up top and never had to move the engine. But that's me
70monte1
44
Aug 30, 2016 01:12 AM
nycmonte
Apr 5, 2014 06:46 AM
jay26
Feb 9, 2009 09:50 PM
2000_BLACK_SS
16
Sep 26, 2006 04:36 PM
bk4256
Mar 28, 2005 06:37 PM
