spark plugs for a n/a 3800
Old Dec 29, 2007 | 11:54 AM
jay26's Avatar
Default spark plugs for a n/a 3800
i been looking into this for quite some time and still dont know what kind to get.i know supercharged guys like copper,but what about for a n/a?my car not as of yet will be mildley modded cat-back, dp., cai,nothing intense. so what should i go for i just want the engine to run smooth and mybe a lil performance.does it matter?thanks, everyone here has great knowledge to share
Old Dec 29, 2007 | 12:09 PM
TrickRacin's Avatar
Default RE: spark plugs for a n/a 3800
I believe the factory replacements are iradium. I put AC Delco Iradiums in mine.
Old Dec 29, 2007 | 10:15 PM
mickey's Avatar
iridums is what i run also the factor plugs were platnium. either work fine but i have noticed a bit better burn on the Iridum plugs and also a better jump on milage but it was minimal like 1-3 miles
Old Dec 29, 2007 | 10:35 PM
z34phoenix's Avatar
NA iridiums are great plugs... yes the stock plugs on these NA cars are platinum. for mild modding iridiums are fine....
my car for example, even though i am still NA i didnt have much luck with iridiums... mostlikely due to not finding a cold enough heat range that i needed... im runing a very agressive tune in the PCM. and although i could prob spend the money on colder iridiums it is cheeper for me to buy the autolite platinums and save money. i can get all 6 plugs for like $12 vs $30 for the iridiums i had before.
the best way to tell what plugs you need is to actually look at your plugs now.... if they are really whitish you need a colder plug... if they are very black (sutty no oilly) then a hotter plug. also all this is assuming everything else is runing good on the car... IE O2 sensor good, coil packs good, wires, air filter, ect are all working fine.
Old Dec 30, 2007 | 07:38 AM
jay26's Avatar
so is copper a bad idea for 3800 n/a
Old Dec 30, 2007 | 08:43 AM
mickey's Avatar
i dont think they are a bad idea, But i dont think they will give you the longevity and preformance tha tthe platnuim or iridum plugs do.
If stock were platnuim it was done for a reason. but i don thtink there is any laws saying you cant change them
Old Dec 30, 2007 | 05:40 PM
jay26's Avatar
well mine is a 01 so i believe they are iridium stock.so whats better between platnum and iridium,i just figure only reason iridium are stock just for longevity,i dont mind changing more if plat. works better.
only reason im thinking this is dont the supercharged come with iridiums too?and they seem to like copper more.
Old Dec 30, 2007 | 06:45 PM
mickey's Avatar
Jay yours were platnium plugs stock
Iridum were a after market choice for alot of the monte carlo owners.
Copper is a good conductor and it would be fine. but the platnuim and iridum plug would last longer and give better preformance over thier life then a standard plug might.
Old Feb 9, 2009 | 08:37 PM
Nova1585's Avatar
i use NGK Iridium IX Plugs I just changed them 2 days ago and i noticed a difference in shifting and firing up...I changed the wires as well tho
Old Feb 9, 2009 | 09:50 PM
kweef's Avatar
zoinks! weve got an old post goin here! lol
silver1
15
Sep 17, 2016 05:15 PM
70monte1
44
Aug 30, 2016 01:12 AM
2000_BLACK_SS
16
Sep 26, 2006 04:36 PM
2000_BLACK_SS
Sep 23, 2006 10:11 PM
bk4256
Mar 28, 2005 06:37 PM
