How Can I GO FAST ??
I own a 97 Monte Carlo LS 3.1 V6 ... In your guys minds wat would be the first thing to do to make this car have more hp/and speed....... and what kind of exhaust thats not to expensive would be good to put on to make it sound mean?? Thanks FOr ur Replies
well sence it's a 97 you have a small port 3100 so the first thing i would do is 00+ 3100 or 3400 top end swap (heads and intakes ) under drive pully, headers and good exhaust system
and you could go with some juice or with a turbo system
just the top end swap alone will get you 30-40 hp (you can port the intakes and open up for a bigger throttle body for more gains )
the best bet for a turbo is ebay get a used grand national it will be more that enuf
as for exhaust i i would go with a 2.5 manderel bent pipe with flowmasters (not sure how they sound on a V6)
but if you go turboi dont think i would hurt to go with a 3 inch system
pasia D
24
Feb 24, 2021 07:24 AM
04 dale jr supercharged
Apr 27, 2010 10:42 AM
